Question about Peg Perego John Deere Gator HPX Ride on Toy
My son pulled the gas peddle off and there are three wires to reattach. In which order do they go?
    Sniper:
  • 70 Answers
There should be two that are close together and a stand alone....the stand alone is red, middle white and then blue
Posted on Mar 02, 2011
The throttle cable is dry rotted and it broke and it seems like the throttle itself is stuck
It can run without the throttle cable as long as where you pointed in video down by the motor, you get a piece of wire or clamp or something of that sort to keep it open. Problem is it is hard to control what speed of rpm. Best would be to order a whole new throttle cable. They come complete in line and they are real easy to put on as you can see there is only a couple screws that hold them. The throttle cable is only designed like your cars gas peddle would work. As you press the gas peddle it opens up the carb to put more fuel in.
Apr 07, 2013 | Garden
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
Dryer drum or rollers or bearings are squeaking on my Kenmore 970-C69042-00 clothes dryer. How do I best trouble-shoot and repair it?
Instructions
    • 1 Turn off the gas to a gas dryer or unplug an electric one. Move the dryer from its position at least 3 feet from the wall. This will give you room to work. Pulling the dryer out into an even more open space may make this easier.
    • 2 Push the putty knife in between the top and main body of the dryer on the front of the dryer. Slide the putty knife near the corner closest to you. Push the knife and pull up to release the pins that hold the top onto the body.
    • 3 Lift the top off the body using a screwdriver as a lever.
    • 4 Label the wires that are connected to the front of the dryer. Make note of which wire goes where. Unclip the wires from the clip that holds them, remove the wires and place them to the side. You will be reattaching these wires later. Be sure to mark them so that you can place them back in order later.
    • 5 Remove the screws that hold the fount of the dryer onto the rest of it. There should be four on most models.
    • 6 Pull the front towards you until the drum inside comes loose from its bearing. Slide the front panel up to reveal the pulleys at the bottom of the machine.
    • 7 Grab the idler pulley. It is the one in front of the motor. Move it to the right to disengage the belt. Remove the belt. Do not remove the belt that goes to the drum.
    • 8 Put on your gloves and slide the drum out of the dryer. Be sure to use hand protection as the edges may be sharp.
    • 9 Inspect the two rollers. If they appear damaged, or you find metal dust under them, your rollers need replacing.
    • 10 Remove the plastic clip on the right hand side if the right roller needs replacing. Remove the metal friction plate, metal brace and plastic clip on the left hand side if the left roller needs replacing.
    • 11 Put on the new rollers and reattach the parts you removed.
    • 12 Slide the drum back in and grab the idler pulley. Pull the pulley to the left until the belt is tight.
    • 13 Slide and screw the front into place and reattach the top.
Jan 15, 2013 | Kenmore Dryers
Need to re-attach internal power wires
Look at the wiring diagram.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 05, 2017 | Kenmore 8000 BTU Single Room Air...
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
Is there a emergency shut off switch for a 1994 Buick Century?
yes it will be in the trunk on the same side as the gas cap pull back the panle and its a little black box with a red or yellow button press it in and it should be fine
Dec 10, 2008 | 1994 Buick Century
Reattach Power LED, Power SW, and HDD LED leads
go to the manafacturer website, there should be plans for the motherboard somewhere on there
Nov 24, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Peg Perego John Deere Gator HPX Ride on Toy Logo
95 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
