Question about Music
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be replaced?>
  • Music Master
  • 5,603 Answers
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Posted on Nov 12, 2010
Key B2 playing to loud, not touch responsive
What is your piano brand and type?
Damage to the contact rubber can cause note plays loudly or,
note does not plays at all.
It is caused by:
1. Carbon rubber contacts dirty / dusty (yellow arrow). Clean with a pencil eraser (or cloth). Gently rub it.
2.
Contact rubber is torn (your case). If this happen,it can not be repaired or glue. So, you have to replace one octave.
The yellow arrow indicates the side that is often torn.
Rubber side that is torn, usually not seen, unless we move / pressing gently on top (In the rubber contact position is not installed on the board.)
Examples of this picture was yamaha psr.
Oct 14, 2015 | Music
My keyboard wont switch on
Check the DC adapter. It may be shorted/broken. This type of stuff happens sometimes.
May 22, 2014 | Yamaha P85 88Key Portable Digital Piano
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Pedals stopped working.
If electronic trace the cable back to make sure connection is secure. Sometimes there is a button that turns sustain off, check control panel to make sure it is switched on. If piano is acoustic take off front panel beneath pedal board to make sure wooden rod is still connected.
Dec 24, 2013 | Music
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
How do I change electolytic coupling caps for a Roland FP-8 Piano?
Replacing the electrolytic capacitors in this keyboard would require you to be somewhat experienced in electronic soldering, especially the surface mount electrolytics. You should be able to find how-to videos on YouTube if you are curious. You also probably do not need a service manual. The values of the capacitors should be printed directly on them. Replace them all. Replacements can be ordered from Mouser. BUT, I suggest at least bringing in a friend that has experience with these types of repairs. These circuit boards are not designed for inexperienced soldering!
Jan 22, 2012 | Music
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
134 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
