Question about Microsoft Xbox 360 Console
My sons exbox has had 3 rins twice and we have had it repaired both times. the third time it had 4 rings, it sat for about two in a half months then we decided to turn it on and it can back on. this happens often! we have had the system for 2 years! what is the problem, our repair shop told us that it would not make sence to keep repairing the system. what do we do now?
    Sergeant:
  • 389 Answers
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
Posted on Nov 12, 2010
Start up, blows black smoke. Been sitting for about a year.
Any oil that was in the head will seep into the piston head over time and this will blow black, but should stop after 1 min.
If this happens over and over with starting every day its a bad seal on your piston rings, this has nothing to do with the air filter.
If your car has sat for that long you need to change the oil asap as oil and gas will go bad after only a few months gas 4-5 months oil will go bad after 3 months or if it has gotten very hot.
Change oil and test to see if your still blowing black if so go get a compression test done that will tell you if your rings are gone.
Ring jobs can be very costly, hope this is not the case.
Oct 31, 2014 | Cars & Trucks
I've now replaced my dryer valve coils for the third time in 4 months. So something is causing them to break down. The problem is the same each time... the coil with three prongs loses continuity. Any
I hate to say it, I only had this happen 1 time in 25 years I been doing repairs. It would have to be the Valve the coils are mounted too. I'm not 100% on this but the 1 time I had it happen to me it went bad 3 times in a month, I spoke to maytag tech hotline and they suggested it, and it took care of the problem for me.
Sep 11, 2014 | Maytag Dryers
Smoking at start up and low trottle
engines that sit for long periods of time suffer from hardening of the seals and rust. There is a very good possibility that the valve stem seal will be hard and cracked allowing oil to be drawn down into the chamber during idling and the rings would have been rusty or running in rusty bores so there will be pitting in the bores. If adding oil is not a problem to you then the oil consumption will only get you into trouble with the pollution police.
Dec 14, 2013 | 1988 Chevrolet K1500
Need code for my oneforall URC-7140 for my Echostar HDS-600RS
If none of these work 0853 0396 0713 1323 1409 1413 try this,
The Search Method allows you to find the code for your device by scanning through all the
codes contained in the memory of the ONE FOR ALL. The Search Method may also work if
your brand is not listed at all.
Example: To search for your TV code: Switch on television (not on standby) and aim
your ONE FOR ALL at your TV.
1. Press and hold MAGIC for 3 seconds until the blue LED (any LED) stays on.
2. Select the corresponding device e.g. TV
3. Press 9 9 1. The blue LED will blink twice (showed by going out twice).
4. Next, press POWER.
5. Press CH+ (over and over) again until your device switches OFF.
6. As soon as your television turns off, press the magic key to store the code.
Congratulations! You should now be able to switch your device back ON and
control your device successfully.
In this example we will set Volume Control (VOL+, VOL- and Mute) to "TV
volume":
2. Press 9 9 3. The blue LED will blink twice.
3. Select the corresponding device e.g. TV.
4. Press and hold the magic key for 3 sec. The blue LED will blink twice and then
Switch off.
Now you have set the Volume Control to "TV volume". The VOL+, VOL- and
Mute keys will always control "TV volume" independent which device mode
key (TV, SAT, DVD or AMP) is selected.
WWW.ONEFORALL.COM 9
OFF
SSAAT/CBL T/CBL
This feature gives you the possibility to
set the Volume (VOL+, VOL- and Mute)
to always control a certain device (e.g.
TV) independent of which device mode
e.g.: Control your TV Volume in SAT
mode.
How to deactivate Volume Control
1) Press and hold MAGIC for 3 seconds until the blue LED stays on.
2) Press 9 9 3.
3) Press Vol +. The blue LED will blink 4 times.
All devices will send out their own VOL+, VOL- and MUTE.
How to remove a device from Volume Control
2) Press 9 9 3.
3) Select the device mode you wish to deactivate from Volume Control.
4) Press Vol -. The blue LED will blink 4 times.
The removed device will send out its own VOL+, VOL- and MUTE.
Search Method
Volume Control
You may have to press
these keys many times
(up to 150 times) so
please be patient.
Jan 13, 2013 | Televison & Video
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Year lo 1 time month lo 2 times weekly 4 times rojulo 6 times vachedi enti ?
year lo 1 time(12 months: 1+2=3 odd)
month lo 2 times(1 week and 3 week these are odd numbers)
week lo 4 times(1 Sunday, 3 Tuesday, 5 Thursday, 7 sat day)
day lo 6 times( 1o clock, 3,5,7,9,11)
Jun 07, 2010 | Nokia Lands Phones
Hi i need the code for one for all urc-7562 for my tv goodmans GTV42P3
Goodmans:
0036 0072 0037 0009
0264 0516 0179 0374
0487 0371 0499 0556
0343 0235 0035 0480
0217 0335
Oct 23, 2009 | One For All URC 7740 Remote Control
4 2 months now, treo 750 keeps hanging up
i think is time for a new phone. sorry
May 02, 2009 | Palm Treo 750 Smartphone
Watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Feb 16, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
