Question about Singer CE-100 Futura Computerized Sewing Machine
How d0 you replase the bobbin case? i had to remove because all my thread got bunched under during embroidery and now it will not fit in right and still gets bunched help please
    Novelist:
  • 233 Answers
The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). From there, you should be able to see the screw in the front you need to move-but be REALLY careful, because it holds two small pieces of metal that will easily fall! If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
Posted on Apr 08, 2011
Bernina 780 sews great, but thread in bobbin keeps messing up while doing embroidery,
Usually, if the thread is messing up under the fabric, it is a top thread issue. This is sometimes referred to as thread nesting or bird nesting.
Make sure you are using a brand new needle of the type specifically for embroidery. The eye needs to be large enough to easily accommodate the thread size and it needs to be a sharp needle. It may help to use a needle with a larger scarf that will protect the upper thread when piercing the fabric. If the thread is not protected sometimes it will hang up on the underside of the fabric when the needle withdraws from the fabric, causing thread loops, etc.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. (This releases the tension disk so the thread seats completely.) Verify the thread path is correct.
Use a bobbin thread that is compatible with the embroidery thread. Check that the bobbin thread is smoothly wound on the bobbin, that the bobbin is turning the correct direction in the bobbin case, and the bobbin case tension is threaded properly.
Retest your embroidery on a small project. If you are still seeing thread bunching up under the fabric, you need to tighten the upper tension.
Balanced Embroidery Thread Tension Must For High Production And Quality...
thread tensioning Madeira
10 Tips for Taming Sewing Machine Tension Problems
Nov 02, 2016 | Bernina Sewing Machines
I have a singer prelude sewing machine - the thread started binding from the bobbin up - there were about 50 threads pierced through my test patch.
what you describe is thread bunching and is typical of the needle thread tension being too loose
adjust that right up, run a test sew and go from there
Aug 07, 2016 | Singer Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Birds nest under the fabric big loops of thread top side looks good...
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Bobbin tread bunches and jams machine
If the bobbin is inserted with the thread spinning the wrong direction this will cause "birdnesting" - thread build up under needle plate, you need to cut thread to get the item off machine. flip the bobbin over into the case and try again. Also make sure you remove ALL thread caught up in "Birdsnest" when they happen.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 27, 2014 | Singer 2263 Mechanical Sewing Machine
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
