Question about Pantech Cell Phones
Is there a way i can turn on my pantech jest without using he power button because the power button wont work due to water damage.
I accidentally dropped my phone in water and then the power button (red) wouldn't work. But then I took out the battery, plugged it in the charger, and then replaced the battery while it was still plugged in. It worked!
Posted on Sep 16, 2014
SOURCE: Pantech Matrix water damage T-T
honestly within the past two days I have gotten my matrix soaked...once in the shower and then my boyfriend threw it in the toilet when we were playing around. the first time I used aerosoft keyboard cleaner and sat in on the vents on top of my tv. The second time I wasn't at home so I filled a bag up with rice and silica bags and then turned it on the next day and it's working fine...I just get this random beep every now and then. And I can see moisture in the corner of the screen. My phone has been through hell. Just do what you think is best and go for it. Not in the freezer though...BIG NO NO
Posted on Jul 11, 2009
fathitkf
  • 1871 Answers
SOURCE: Replacement Screen for Pantech C810
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
SOURCE: My pantech jest will not
I just started having this problem as well so you aren't alone. Maybe they are from a bad batch. I tested the battery with a multimeter and it has a good charge so it looks like the phone isn't taking in the power from the battery for some reason. I think the only solution is to have it sent in, unfortunately.
Posted on Nov 20, 2010
tbreeze47
  • 3083 Answers
SOURCE: my pantech jest phone is
The push button contact pads inside the phone are either dirty, oxidized, or worn. If the phone is still under warranty, enforce it to have it fixed. If not, take it into your provider and see if they can assist you in fixing it, since they often know how to do this. If the unit is out of warranty, and the provider can't assist you, you can take it apart, and try to clean the button contacts with an electrical contact cleaner, or a qtip and alcohol, or a pencil eraser. If that doesn't help, the phone will have to be serviced. Contact Pantech for assistance:
http://www.pantechusa.com/support/
Good luck, and hope this helps.
Posted on Apr 15, 2011
SOURCE: i have had 4 pantech
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Posted on Jun 13, 2011
Need manual or hack... would like to use the web
Here you will find a download of the manual for your device...
Pantech Jest TXT8040 User Manual
Jan 18, 2016 | Pantech TXT8040 Jest
Power button wont wrok on pantech marauder
yes, you will have to repair the power button then it will be able to power back up.
Apr 20, 2014 | Pantech Cell Phones
Pantech Hotshot My Verizon
IS the hotshot considered a smartphone? you may need to upgrade the data plan. Another trick by the mobile carriers $$$$$$$$$$
Mar 12, 2014 | Pantech Cell Phones
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Dec 27, 2010 | Cell Phones
How do i use the camera on a pantech jest?
The following link has a video that will explain how to use the camera.
http://www.wonderhowto.com/how-to-use-camera-verizon-pantech-jest-phone-389610/
Oct 29, 2010 | Pantech Cell Phones
Few drops of water got on my Pantech Slate phone..now keyboard does not respond..help!
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Aug 16, 2009 | Pantech Slate Cell Phone
Pantech matrix got wet wont charge
your battery is probably bad. take out the battery and plug it up and try to turn it on without the battery in. if it works just replace the battery. if not then your phone is fried.
Jul 14, 2009 | Pantech Matrix Cell Phone
Phone wont turn on
You'll need to take it to a tech so they can clean the water damage and oxides that have accumulated inside. You answered the problem on your post by saying the phone has water damage.
Jun 05, 2009 | Pantech U4000 GSM UNLOCKED 1.3MP CAMERA...
Pantech c150 will not turn on
Hold the power button down. My wife's took almost 30 seconds to power on.
Feb 06, 2008 | Pantech C120 Cellular Phone
Cell Phones Logo
760 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
