Philips 47MF437B Hi, this Tv will all turn for about 1-3 minutes then shut down. Any suggestions? Thanks
  • 1 more comment
  • Jeff
    Jeff Nov 10, 2010
    Yes I have replaced two bulged capasitors on the a/v board but no change, and changed the 2200mf 16v cap on the power supply board but no change. thanks
  • Jeff
    Jeff Nov 11, 2010
    Philips 47MF437b This tv will come on for 1-3 minutes then shut down. all caps look good with no bulges and no holes. any suggestions? Thanks
  • Jeff
    Jeff Nov 11, 2010
    Hi, the tv does come on for 1-3 minutes then shuts down, and I have replaced two 1000mf 25v caps on the a/v board and one 2200mf 16v cap on the main power supply board but no change. tv is 2007. there is chirps when turned on. thanks
  • 5,138 Answers
How old is this TV and have you removed the back to look for Bad Capacitors on the Power Supply board?
Posted on Nov 11, 2010
  • 10,515 Answers
Kindly provide few more details :-
1. Was there any power surge?
2. How old is the unit?
3. Do you hear any chirping or clicking noise?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 4,889 Answers
The tv is shutting down due to overload exerted on it by the components on a particualr voltage line. Possible locations are power supply board or the main audio/video board. The first thing you should check for are faulty capacitors on the two board. Look for capacitors that are swollen or cracked at the top. Even tiny holes at the top mean that the capacitor is faulty and needs to be replaced.
Posted on Nov 10, 2010
  • eagle338
    eagle338 Nov 10, 2010
    It is possible that there are more of them. Sometimes its best to use a multimeter set to capacitance mode to test them. If its a normal protection fault, the tv does not take this long to shut off. It will turn off instantly in a second or two. So I suggest that you test them with a meter to see if you find anymore faulty ones.
  • eagle338
    eagle338 Nov 11, 2010
    Ok. So what do you wanna do? If you wanna test the other components on the board I have no problem. I can find you a service manual and we shall begin.
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
TV wont stay on longer than 15 minutes
Sounds like your power board is shutting down as it gets hot. I would get prices for and replace the power board!
Mar 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
TV shuts off after about 30 minutes and have to unplug and reset
Go to the Philips website and see if they have the problem listed; if they do, they probably can identify the solution. If not, the website should have a link to answer quesions.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Sep 12, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
