Question about Crosley CWDH11W Front Load Washer / Dryer
Crosley front load washer one year old. doored
Crosley front load washer one year old. doored locked, washes to a point and stops not draining the water out. door stays locked since washer filled with water
  • Anonymous Mar 17, 2014
    my crosley washer wikk not fill
    President:
  • 2,468 Answers
Your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Have a whirlpool AWO 3551 washing machine. Door locked light flashes and machine stops at random points in the program. Pump works OK and drains water. Don't suspect door lock module as washer works on...
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Jun 17, 2008 | Crosley CW5000 Front Load Washer
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Crosley CWDH11W Front Load Washer / Dryer Logo
195 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
