Question about Sharp AL-1655CS Copier
Paper How can i remove the paper that is jamed in printer magicolor 3430 dl
  • Tim Babcock
    Tim Babcock May 11, 2010
    Where is the paper stuck at?
  • 97 Answers
Note: Turn Off the machine for Safety Used.
- Check the Fuser Assembly if they have a pieces of paper stuck.
- Reinsert properly the Toner Cartridge Assembly.
- Check all sensor if they have a pieces of paper stuck or dust.
- All assembly and door covers needs to properly inserted.
Let me know if the machine is working?
Posted on Sep 24, 2008
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta 7416MFG saying paper jam but i removed sll the papers without tearing
the door or cover is not properly closed or it may still have piece of paper inside it.
May 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
I have some small pieces of paper stuck in the fuser unit from a sheet that got stuck - how do i get them out as I cannot see them?
Start to dismantling it untill you are able to see the paper and then with tweezers remove the paper carefully
May 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
It no longer takes the paper, no matter how much paper is in the tray it starts to take it, but will not take the paper all the way through.
Remove the toner.
Clean the roller (round rubberized black thing inside the printer) with dump-clean cloth manually turning the roller to clean entirely.
Apr 17, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magiccolor 2350. Paper jamed(paper end only)in
Kindly open the delivery door and back side of the printer. Check the space between metalic roller and the plastic with the help of a pin or something thin like ruler. Probably a pin or stappler might be stuck there just remove it. your printer will work fine. Secondly check that if any plastic is burnt or melt over there if so then use something rough to make it plain.
Feb 17, 2010 | Konica Minolta magicolor 2400 Laser...
Fragments of paper inthe fuser
The only way I was able to clear fragments of paper from the fuser was to remove the fuser it was then easy to remove the paper fragments. Before you do that you could try manually pushing a 5 inch strip of a manila folder up through the rollersl although that did not work for me.
Aug 02, 2009 | Konica Minolta magicolor 2430 DL Laser...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Sharp AL-1655CS Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
