Pacific Laser Systems 90ESYSTEM 90 Degree Self Level Laser with Detector(P Logo
Posted on Nov 10, 2010
I have a PLS3 laser its got two dots & not shoting plum it is about a 1" out where can I send it to get it fixed
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1805
Points
I know Star Equipment in Des Moines, Ia. does service on them.
How do I calibrate porter cable laser RT-7510-3 laser light works but stuck out of level
The handhelds are not meant to be calibrated, recycle properly and invest in a PLS3 or PLS5, they have a 3 year exchange warranty: https://www.plslaser.com/pls-best-class-warranty/
2answers
My new pls5 laser will not light when turned on. It's only 4 months old. Never dropped or even wet. Anyone else have this problem? And can I fix it?
In my experience, on PLS found several times the power button defective after few weeks/months (especially if You work in construction sites ).
The ultimate fix is new power button (not replace the old one!) in a convenient position. I have fix several PLS3:
25648370-ud5esjubpx2k2ouh2wsyjwog-2-0.jpg Notice: if You open your PLS5, You have to break the lateral sticker and the warranty will be void!! Keep this in mind!!
Bye!
Nikon coolpix s4300 keeps saying file contains no image data
Call Nikon they can fix it they ask you to send it to them and they tekk you how much you send it and they fix and mail it back it shouldnt cost that much nothing is broke.
2helpful
&@" rear projection..........numerous blue dots
Problem is called the optical block. Sony has issued a major recall. If you contact them they will offer you a tv a discounted price. Call 1-800-282-2848. Tell them your problem and they will set you up. Hope this helps.
1helpful
2answers
My brand new 160gig ps3 freezes during gameplay and takes forever to load movies and games. What's going on?
The disc reading problem is HUGE!
It happens because the laser has come away from where it needs to be and to fix it you need to readjust the laser.
Now you can do this by sending it in however there will be a charge for the fix.
The other way that you can fix it is to use a good repair guide.
I hope this helps?
3helpful
2answers
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
My Phaser 7700 Printer does not come to a ?Ready? state
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
I have a pls3 yellow laser and when i've changed the batteries it is completely dead
have you got the batteries in right?if it worked before you changed batteries,then the new batteries may have been put in wrong or the new batteries might not be any good.check
1helpful
2answers
SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Top Pacific Laser Systems Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Pacific Laser Systems Measuring Tool and Sensor Expert? Answer questions, earn points and help others
