Question about HP Color LaserJet 2600n Printer
HP 2600 Printer Problems
I just installed a new black ink cartridge, but its still saying "replace cartridge". What should I do?
  • Anonymous Jun 30, 2008
    I have the exact same problem. I have installed a new factory cartridge and it showed I needed to replace it, even though it was new. I installed another new cartridge and it again showed I needed to replace. I have cleaned the connection area so the printer could read it as being full. ANY OTHER IDEAS? I love this printer and it is only about one year old.
    Problem Solver:
  • 7 Answers
If this is a reman cartridge or new. Take it back and get a different one. Their is a little chip on the cartridge that may have glue on it, been installed upside down or if it is a reman someone may have forgotten to replace the chip.
You might also want to check where this chip makes contact with the printer to make sure you do not have any tonner dust or have something obstructing the contact between the cartridge and the printer.
Posted on Jun 18, 2008
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
The printer says that the black ink cartridge is bad. Replace
Please use HP 94 or HP 96 black ink cartridge.
Regards,
Rizwan.
Mar 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Says Black ink supply expired. Installed new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
I have an HP Deskjet 6540 which I have owned and had no problems with for 2 years. Yesterday I replaced the ink with new hp ink cartridges number 96 and 97. However, the printer is not working and the icon...
When the carriage is worn out it doesn't hold the ink up to the contacts inside. If you remove the ink and place a small piece of paper behind the connector inside it will move the contacts out to the cart. Also try a piece of tape on top center of cart to hold cartridge in to the contacts better.
Oct 29, 2009 | HP DeskJet 6540 InkJet Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Cartridge problems
Ref: our live chat - Definitely worth replacing the colour one with a new one - some other people had identical problem and that cured it - they really don't survive not being used very well. :)
Apr 21, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
