Question about GE Dryers
Gas drier does not heat up or dry clothes - GE Dryers
    Guru:
  • 1,894 Answers
I think the heating elment is not receiving proper supply
u can ensure that it receives proper input
post problem in detail
Posted on Jun 17, 2008
    Brigadier General:
  • 3,614 Answers
May i know the exact model of your dryer..?
  • micromaster
    micromaster Jun 17, 2008
    1. check for any blown fuses on your dryer.
    2. check for the heating element, use a ohm meter to check this part..
    3. look for the blown thermal fuse at the exhaust duct,.
    4. & also check the electrical wiring inside the unit.
    let me know here again.
  • 796 Answers
Can you mention the model number??
  • isaac johny
    isaac johny Jun 17, 2008
    First pull your dryer away from the wall, then take off the exhaust
    hose and run a load, if no improvement, then its likely one of your
    heaters is bad. You would have to then unplug the dryer then take it
    apart.
    This link will help you do that:
    http://www.applianceaid.com/ge-dryers.ht... http://www.applianceaid.com/ge-dryers.ht...
    Here is the new element for your model:
    Heating element assembly with housing http://www.repairclinic.com/referral.asp...
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
FGR231ASY GAS DRYER BURNS FLEESE MATERIAL CLOTHING WHY
Hello my name is George,
I was wondering if the dryer was just burning fleece or all of your clothes. Fleece is a very delicate material, and should be dried on low temp or delicate depending on your drier. Driers are thermally protected inside with various parts. If the drier is getting to hot one of these would have caused the drier to stop heating. If the drier is burning all the clothes and not just the fleece I would recommend having a technician come out and check it as this could be a hazard for you and your family.
Oct 26, 2012 | Dryers
Zanussi tumble drier is not heating up to dry clothes , but is working OK otherwise
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Dryers
Suddenly drier spins ans work as usual but does not heat up. therefore, clothes are not dried even after three hours of spin.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 29, 2010 | EuroTech EDC158 Electric Dryer
No heat when drying cloths
Check the vent that goes outside it may be blocked.
Jul 23, 2010 | Maytag Neptune MDG9700A Gas Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
