Question about Zebra 105SL Thermal Label Printer
The printer keeps skipping lables. Eg: I tell it to print five and it prints one, a blank one, prints another one, a blank one, and then prints one more.
    Champion:
  • Zebra Expert
  • 285 Answers
There is 2 sensors unther the printhead, the downsensor (small metalic case unther the labels) and the uppersensor (black plastic bit wit a scwer on the top. Thwy have to match, check if they are at the same position, run the SENSOR PROFILE, see if you can see the gap. Run manual calibration. save. restart the printer.
Posted on Nov 12, 2010
Lables getting printed alternatively
This is due to :
Wrong size of label.
You must give a page size and the gap size
It is very important to give the correct height and ga dimensions
The detecting sensor chosen is not the right one
Nov 27, 2009 | Toshiba B-SA4TP Printer
Printing labels
you may have to set the lables up on the bypass or manual feed input as the machine has to compensate for the thickness of the labels and slows the print process down. check the display on the copier it may be asking to load labels in the bypass
Nov 17, 2009 | Office Equipment & Supplies
Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
May 28, 2009 | Zebra 2746e Thermal Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Sugest my problem
Will printing 4 lables and then will skip 4 lines and then print again
Mar 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing Round Labels
the issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
Nov 12, 2007 | Zebra TLP 3842 Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
188 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
