Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Murray 17hp OHV/42" Wide Body. The deck belt snapped from wear and tear but when i replaced it, the deck no longer drops down and engages. I am 99% sure i have the belt on correctly but do not understand why the deck no longer drops and the blades do not engage. Any suggestions would be appreciated. Thanks!
  • Matt Olenzek
    Matt Olenzek Nov 11, 2010
    Hello, When you replaced the belt did you reemove the deck?
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 86 Answers
SOURCE: won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
Posted on May 10, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
panilling9
  • 284 Answers
SOURCE: How do I adjust the brakes on a Murray 17hp 42
find your brake disc on your trans axle
find the 1/2 or 9/16 nut on the outside of the brake disc and turn it clockwise1/8 turn and retry your brakes 1/8 turn. at a time until you achieve adequate breaking
do not overtighten that nut as if you do you will not be able to move your mower in neutral after you let out on the brake /clutch
Posted on Jun 09, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
I have replaced the mower drive belt..the belt from the tractor to the mower deck 4 times...usually after only 2 or 3 uses and at about 50 bucks a pop each time. After the 2nd time I replaced a pully that...
Considering what you are paying for belts, I would very much suggest you schedule a repair at the shop. Less cost. Also, if it still snaps a belt right after they have had it in, they will replace it. Very odd, the clean snapping. Makes me wonder if there is a malformed surface contacting the belt intermittently. Farmerbear at FixYa.com
Sep 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Part # needed
most B&S 17HP Take the same starter up to 20 hp single
Jan 22, 2018 | Garden
The belt is too loose on my 42" 17.5 Murray rider mower. Where can I find the adjustment?
Hi how old is your belt, if it is an original one or even a replacement with use go to your local repair shop and get a new belt --- take your old one so they match it up as well as your make--model---serial number of the mower. this will get you the right belt. you have a pulley that should take up the slack so I would look at the belt for streching and wear.
Oct 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
I need to replace a belt on a craftsman with a 42" deck.What size belt should I get.What length.
Craftsman is made by Murray Corp. who also makes Murry, YardMan, Lowes, Penncraft, and on and on. Go to your local Wal-Mart, Lawn and Garden Dept. and look for the belt that fits the Murray, YardMan, Lowes, Toro, 42" Deck 14-18 HP. Or take your old belt with you, and stretch them both end to end holding the end loops with each hand. Or you could go to Sears and just tell the parts department what your mower is and they can get you a Craftsman belt. It will be the same one you get at Lowe's, Wal-Mart, ect, probably just cost a little more. Sears doesn't make mowers, they just have their colors and names put on by the manufactorer. And Murray of Ohio is the maker of these.
Sep 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drive belt broken
That's a deck belt for a 42 or 46 in cut Murray deck. The size is 11/16 ths wide X 66 inches long. This is a wide belt .GOOD LUCK
Jun 22, 2009 | Garden
How do I adjust the brakes on a Murray 17hp 42'' twin cylinder wide body?
Jun 09, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
280 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
