Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Hi - I am looking for a westinghouse sb907 service manual so I can track down why it doesn't heat the water anymore - everything else seems to work OK..
We have the same problem, we replaced the element and still no heated water.
Posted on Dec 01, 2010
  • alan318 Dec 02, 2010
    I eventually got a technician in who diagnosed a control board failure - he just took a reading on a meter to confirm it, but said that it is a common problem - the control board fails often enough to be regarded as a design fault.
    Was a bit upset at paying nearly $300 to fit a new control board - kind of wrong to pay for new controls for ALL functions when only one had failed....but Electrolux were pretty much 'tough luck' when I asked if they could supply the control board at reduced cost. So much for their customer attitude :-)
  • 5 Answers
Save some money and fix it yourself if it fails again.
http://www.fixya.com/support/t640534-westinghouse_sb915_will_not_heat
Posted on Apr 04, 2013
Does anyone have a manual for a westinghouse dishwasher sb907
Download that here
http://www.westinghouse.com.au/SupportCentre
You need to specify whether SJ - stainless, or WJ - white painted, although they will be the same.
Dec 11, 2011 | Dishwashers
Hi, My westinghouse dishwasher SB907 goes through the washing cycle but doesn't seem to heat up and use the hot water. I have changed the little switch thing, that costs around $20, so what else cold be...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
My Westinghouse dishwasher SB907/915/925 is not heating water.
I have had the same problem. I removed the heater element and checked the resistance with my multimeter and got the reading of 26.4Ohms which sees ok. I then removed the printed circuit board and found that a joint on the back had burnt out. I have resoldered this joitn and all seems fine now.
Jul 14, 2010 | Westinghouse 24 in. MDP531 RF...
How do I actually get to the circuit board on dishwasher
Undo the top two screws on each side of the back of the door and all the ones across the top edge. Then the panel can be manouvered away from the door. The catch mechanism tends to hold the panel back and there is only just enough free length on the wiring to pull the panel away a couple of inches, but it's enough to access the on/off switch and control module.
Feb 10, 2010 | Westinghouse Dishwashers
Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Jul 12, 2009 | Westinghouse Dishwashers
Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
Sep 15, 2008 | Westinghouse Dishwashers
Westinghouse sb915 will not heat element shows 25 ohms when tested.
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Jun 02, 2008 | Dishwashers
Dishwashers Logo
1,423 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
