Question about Kyocera FS-2000D Laser Printer
Our FS2000D keeps forgetting it has a 2nd casset tray. I am having to go into properties daily (at least) and tick the box. This is a pain. Any ideas?
  • 165 Answers
Very stange 1st thing u need to try is upgrade firmware and perhabs take the tray off completley and re fit it again Make sure the connector on the tray and the copier not damaged in any way
Posted on Nov 10, 2010
Vcr/tv how to get the carriage unstuck
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Nov 15, 2015 | Televison & Video
Tray 2 wont print kyocera fs2000d
you have to go into the print driver settings and tell the driver that tray 2 is installed. kyocera support website can help with instructions for print drivers
Jun 28, 2013 | Kyocera FS2000DN Laser Printer
Can a simpletech external harddrive work with windows 7
It can but windows 7 is a real pain with large external drives even large usb pen drives.
I have steered well clear of using large usb external drives on windows 7 got nothing but problems.
Here are some of the possible problems and fixes you might have to correct.
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7
good luck
Feb 11, 2013 | Computers & Internet
Wifi
Try going to control panel > network connections
right click the wireless connection and select properties
at the bottom of the window is a tick box for displaying the system tray icon, tick it.
You could try a right click on a blank area on your task-bar goto properties then untick "Hide inactive icons", it may help.
If not go here, theres a bunch of ideas that could help you.
Jun 19, 2012 | HP Pavilion ze4300 Notebook
I have an 8 gb sandisk pendrive. but now it shows only 4 gb in properties. how to tackle this problem?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
restore defaults
In XP
If you need more help with this post a reply
hope this helps you
Apr 10, 2012 | Computers & Internet
Computer keeps telling me to format usb stick if i do i lose all my data
click start control panel administration tools computer management disc management right click on your drive select properties tools check now scan for and attempt to recovery bad sectors and
automatically fix any file system errors tick in both boxes or tick one box then wait until it has finished then return and tick in the other box
i have found the best results ticking the first box then returning after chkdsk has finished automatically fixing files
you should have no input while chkdsk is running any input might further damage your hard drive
hope this helps you
Feb 17, 2012 | PNY 4GB Micro Attache USB 2.0 Flash Drive
My Dane-Elec 8GB will not format. I have tried two different jump drives and I keep getting the same message. Unable to complete format.
WHAT A PAIN IN THE A_S_S.
DID EVERYTHING DESCRIBED, & MORE,
& I'LL NEVER WASTE ANOTHER PENNY ON
ONE OF THESE F_U_C_K_I_N_G PIECE OF
S_H_I_T DANE-ELEC 8GB .
I'M GOING BACK TO TARGET STORE & JAMMING
THIS NIGHTMARE RIGHT UP THE STORE MANAGER'S
STUPID A_S_S .
Sep 12, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Oct 06, 2009 | Kyocera FS2000DN Laser Printer
Network problem
go to control panel
network connections
locate your wireless connection and right click on it
left click properties
locate the tick box that says shown icon in taskbar and put a tick in the box
ok everything to return to desktop
your icon should now be in the system tray
Jan 06, 2009 | Computers & Internet
HP dv2660 Sp. Ed.
try right click anywhere on desktop go to properties/display settings
it should show 2 monitors you may have to plug 2nd monitor in and on there should be a box to tick for 2nd monitor hope this helps
Jul 03, 2008 | HP 418446-001 - HP Special Edition L2000...
Kyocera FS-2000D Laser Printer Logo
60 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
gggg
polytek
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
