Question about Homelite Mighty Lite Blowervac
Blower runs,but runs on high,canot contral blow rate?
  • joemar08 Nov 11, 2010
    when you engage trigger it chokes out. please advise more.
    Thank you
  • 718 Answers
I have never heard of a blower that you can control blow rate, there is nothing wrong with your machine!!!
Posted on Nov 10, 2010
  • vince janis
    vince janis Nov 13, 2010
    You need to clean and rebuild and your carb. You can find a rebuild kit at your local repair center.
My audi a4 only blow heat on when it is running on high speed
You have a defective HVAC blower motor speed control resistor, replace it. When they go bad they only allow the blower to work on high speed. The resistor is located near the blower motor.
Nov 24, 2016 | Audi Cars & Trucks
Blower blowing just not much
in all modes, even moving real fast in fresh air mode
no vent blow? weak in hot mode and cold?????????????????
no year stated,so answer will be kinda(weak,)
(weak and. tragically generic, is that good?, no)
1993?
see? this is 2016, so.....
lots of EVOLUTION to the EXTREME here.
for sure the climate control option.?
like Gemini 1 to Space X?
weak blower, the filter is dirty:?
hvac self tests fail? (read hvac page in FSM see it?) ask.
12vdc to blower pins, on high?
yes, then blower is weak(means bad)
or there are restrictions, then
top restrictions are dampers stuck
or
controls to dampers MALF'ING.
or dead mice nests,
TELL MORE GET MORE.?
Jan 31, 2016 | Jeep Grand Cherokee Cars & Trucks
1992 gmc pickup keeps blowing heater fuses I replaced the blow motor and it keeps blowing
Have you replaced the blower resistor . some times they can cause the fuse to blow . You may need a muiltmeter to test the current draw on the blower motor circuit. the draw should be less then half of the rated fuse .( 20 amp fues draw is less then 10 amps) You did not say but does the blower work on high only or the lower speeds with out blowing the fuse ? if it does work on low or high with out blowing the fuse i would replace the blower resistor
Mar 06, 2011 | GMC Sierra 1500 Cars & Trucks
Aircondition fan motor changed running ok but little air through vents
Does it still sound like its on high? If so you could have your vents blocked/restricted or your blower is not blowing on high speed. Usually a blower resistor if not blowing at max or not blowing at all speeds
Dec 03, 2009 | 2001 Lexus RX 300
Heater blower only blows on low
This could be a few different things:
1.Check the power and ground connections on your blower motor, corrosion can cause high resistance and a slow blower speed.
2. Check your available voltage at the blower motor on the different settings. it should vary with high supplying 12volts, make sure to do this check with the blower motor still plugged in.
3. Connect the blower to a 12v power source and see if it runs at high speed.
If all else fails i would check your resistor pack, i would not suspect this because when it fails you usually just loose all speeds except for high, but it could happen.
Feb 25, 2009 | 1999 Chevrolet Silverado 1500
Front blower motor doesn't work, rear does
yes, all blower motors have them to control their speed, High, medium, low.. etc. I earn nothing by helping you, but my rating, a fixya rating and I will walk you through this
Dec 20, 2008 | 2005 Chrysler Town & Country
Blower only runs high
probaly the blower motor resistor.
when a blower motor resistor blows your left with only one speed.
Nov 15, 2008 | 1998 Jeep Cherokee
Homelite Mighty Lite Blowervac Logo
49 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
