Question about Visonik V2508 2-Channel Amplifier
Will it go into protect mode when a fuse is blown?
    Scholar:
  • 71 Answers
Protect mode is normally when there is to much power running to the amp. if a fuse is blown it normally wont turn on. but take your fuses out hold them to a light and you will be able to see through the fuse. there will be two prongs that will be connected by a U shaped piece of metal. if that piece of metal is still in tacked the fuse is good. you should have a big fuse running with your major power. also check your ground if your ground is loose or has a bad connection. and make sure the the subs go to the amp. if the subs are drawing to much power from you amp it will go on safe mode as in if you have a 2 ohm amp and a 4 ohm speaker. i hope this helps you.
SabiousOne
Posted on Nov 11, 2010
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
I have a volfenhag zx-8400 and it just geos into protection mode
The most likely problem would be a blown fuse. I would replace all of the fuses.
Oct 04, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Amp in power protect
Protection Circuit is bad. It needs to be serviced. If all speaker wires are disconnected and it's still in protection, it's got a problem. Hope this helps
Aug 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Protect Mode
Make sure that you are not asking too much from your system by having a "heavy" bass contour, or processing externally that amounts to the same thing...accordianman
Sep 27, 2007 | Sony STR-DE597 Receiver
Visonik V2508 2-Channel Amplifier Logo
128 people viewed this question
Top Visonik Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Visonik Audio Player and Recorder Expert? Answer questions, earn points and help others
