How do I tighten a loose drum on a maytag neptune MAH3000aww. There is alot of noise when washing or spinning
  • 147 Answers
You can not tighten the belt you have to replce the bearing
Posted on Nov 11, 2010
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Jan 31, 2010 | Maytag Washing Machines
Mah3000aww leaking water
You need to replace both tub bearings and the seal. Not an easy job. Good luck, though.
Jun 15, 2009 | Maytag Neptune Washer
I have a maytag neptune front end washer. model #
hi..
First clean out your outlet filter. If this does not work, open up behind and tighten all points where wires are joined; due to vibrations these might have come loose. Plug off the wall first!!..
thank u
May 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loose drum on washer
you do not tell me alot about the problem,so im going to hazard a guess; get your drum belt tightened or replaced this will fix your problemhope this helps.adrian
Feb 18, 2009 | Maytag LSE7806A Top Load Stacked...
Spin cycle is very loud but works well
my neptune was so loud it sounded like it was taking off, it turned out to be the bearing in the drum, the repair man wanted $1200. to fix it. i called maytag and this part has a lifetime warranty and they sent it to me in 2 days.
Feb 11, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
