Question about LG 26LC7D Television
LG 26lc7d will not turn on.Power light flashes green. Any Idea ?
xptareq2000
  • 1447 Answers
SOURCE: I have an LG 42
When your TV (EHT) High voltage is not proper run or Power supply is not strongly create voltage.
Solve: If you repair it self,You check thoroughly.Some of components may be damage in power supply.
Check diode,capacitor or high voltage power transistor,any kinds of fuse.
Posted on Jan 07, 2010
  • 1039 Answers
SOURCE: lg 32lcd tv's - does not power up - flashing green light
Replace any swolen capacitors on power board. If still not working replaced main board.
Posted on Aug 29, 2009
  • 148 Answers
SOURCE: i have a lg 26lc7d tv and the red light is orange
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not )please rate, thank you!d539576.jpg
Posted on Feb 04, 2010
supertech6
  • 513 Answers
SOURCE: I can't turn on my 32 inch plasma tv by LG.A green
The flashing indicator is telling you the fault. Give the number of flashes to the LG service department and they can help you with your issue. It will likely need service.
Posted on Mar 30, 2010
toolkits
  • 1099 Answers
SOURCE: LG TV won't turn on. Power light flashes red/green.
Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 31, 2010
Testimonial: "good advice"
42 inch LG plasma tv will turn on green led will flash 3 times and then turn off
Check and replace its main digital board. after replacement, somde adjustments have to be done, and you have to enter its service mode option to do it. Really it is a skilled work, that a customer who has no idea in electronics can do.
Aug 25, 2012 | LG 42PC5DC 42 in. Plasma HDTV
26lc7d green light
Either set is on or not---question could use some more explanation if possible.
Jun 14, 2012 | LG 19LH20 19 in. LCD HDTV
Will not turn on, green light is flashing...
Flashing green light usually indicates the TV is need of repair. This is the TV's way of letting you know that its needs to be fixed by your local tv repair shop or to contact your tv manufacture. Hope this helps.
Apr 25, 2010 | LG 26LC7D Television
WONT TURN ON LIGHT FLASHES RED AND GREEN
i have the same tv with the same problem! tv repair said they could not get the part. im still looking.
Jan 06, 2010 | LG 26LC7D Television
I have an LG 26LC7D and the picture from the
is the rf connector loose? if so a tech will have to open up the set and try to reattach the coax connection to the mainboard
Dec 07, 2009 | LG 26LC7D Television
The led light is green but there is no image or sound in any mode, not even conectin a dvd player
this could be the main module in the tv,I would contact a servicer in your area
Oct 13, 2009 | LG 26LC7D Television
Televison & Video Logo
299 people viewed this question
