Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
I only have two decimals for an answer and would like to get the true result.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press MODE to open the mode editor. Select "Normal" and on the next line select the number of digits you want to the right of the decimal point.
Posted on Nov 10, 2010
How can i change my calculator so the answer will be in decimals instead of exponents or fraction?
There is a misconception hiding here in your statement. A decimal result on a calculator is often no more than an approximation: Try expressing 1/3 as a finite decimal representation. So, the only exact results that you may get are those displayed as fractions and those with radicals.
Now let us address your question. The calculator has a limited display capability. Any decimal result that is too small or too large to fit in the display window will automatically be displayed in scientific notation (the one with exponents).
If you want exact results, you should set the Input/output to MathIO. Even then, if the expression requires more display space than is available, it will be displayed as a decimal number.
Sep 12, 2012 | Casio fx-300ES Calculator
Wont put answer in decimal form Example 252/5
To compute a single result in decimal, press diamond ENTER instead of ENTER. You can also use diamond ENTER to convert a result to decimal. To have all results come out in decimal, press MODE F2, use down-arrow to move down to the "Exact/Approx" line, press right-arrow, then select "APPROXIMATE." Press 2ND [QUIT] to exit the mode screen.
Jan 18, 2011 | Texas Instruments TI-89 Calculator
I want to get an answer in decimal form but it only gives me them in fraction form. What should I do in order to change the settings to give me answers in decimal form?
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 14, 2010 | Casio FX-115ES Scientific Calculator
I have a CASIO calculater when i try to devided 3/2 i am getting same answer how to change this in decimal place on the calculater. I mean the answer is 1.5 for the above nubmers but i am getting 3/2 how...
To convert a single result to decimal, press the S--D key. To have all results come out in decimal, switch to the LineIO mode by pressing SHIFT MODE 2.
Nov 13, 2010 | Casio fx-300ES Calculator
How do i change the answers from fractions to decimals
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Oct 20, 2010 | Sharp ELW535 Calculator
How do i convert fraction answers to decimals?
If result displayed is to be converted, press the S-D key. This will toggle display from decimal to fraction and from fraction to decimal.
To force a result to be in decimal format press SHIFT = instead of just =.
To configure calculator to display only decimals, press the SHIFT MODE key sequence to enter SETUP and seledct 2:LineIO.
Oct 14, 2010 | Casio fx-300ES Calculator
When I enter 55/2 - the answer appears as a fraction. I would like for it to appear as a decimal. I know I can convert the answer using the SD key, but I would like the initial answer as a decimal.
To get the result in decimal format, press [SHIFT][=] instead of just [=].
You can also configure your calculator to show only decimal results:
  1. Press [SHIFT][MODE] to access the (SETUP)
  2. Select [2:LineIO]
Aug 12, 2010 | Casio FX-115ES Scientific Calculator
How to get answer in decimals instead of fraction
if you do not want to change your settings There are two ways to foecr calculator to display a result in a decimal format.
  1. Before pressing the [=] sign to get the result press [SHIFT] key. thus [SHIFT][=] displays a result in decimal format.
  2. If a result is already displayed and it is not in decimal format (fraction or radical) press the [S<=>D] key to convert it to decimal.
  3. The [S<=>D] key toggles between formats (fraction/radical to decimal and from decimal to fraction or radical depending on the format used in calculation.)
  4. That does not mean that every decimal number can be converted to fractions/radical.
If you want to have all results in decimal format you can configue your calculator to always do so. All it takes is to set LineIO as the default Input/output format.
Press [SHIFT][MODE] to access (Setup) and select [2:LineIO].
Just in case you want to revert to the other IO mode (MthIO)
Press [Shift][MODE][1:MthIO]
Feb 15, 2010 | Casio FX-115ES Scientific Calculator
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
23 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
