Question about Samsung DV218AEW Electric Dryer
Dryer power is on, cycle starts but dryer drum doesn't spin, we may have broke it by turning the drum by hand to retrieve a particular garment, heard a lot pop or snap sound.. now dryer doesn't spin.. any idea as to what we did or what the problem is..
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My servis tumble dryer wont spin i have had a look and the belt hasnt snapped and the motor is still working
Do you hear the motor turn on when you start the dryer? If the belt is loose then it could cause it not to turn.
1. If you are able to run it with some of the housing removed, then do that and verify where you are losing your ability to spin.
- Make sure the motor is engaging and actually turning the belt. If it is turning and moving the belt, check to make sure the belt is routed correctly and not slipping on any of the pulleys. If it is, then it may just be time to change the belt.
- If the motor does not spin, listen to the motor and see if you can hear it kick on when you try to start a cycle. If you don't hear anything, turn the power off (unplug from the wall to be safe) and disconnect the connection to the motor. Use a voltmeter or multimeter and connect the probes to the two pins that provide power to the motor (can't say which ones specifically. There may be a service wiring diagram tucked away inside the dryer houseing somewhere.) Plug the dryer back into the wall try to start a cycle which observing the meter. If you are getting no voltage then the motor is not getting the signal to kick on, which means it is some kind of controller device (timer switch, selector switch or control board depending on your device) or a relay. If you hear the motor kick on but won't spin, there are a couple things you can try (unplug the dryer first for both): 1) Take the belt off the motor pulley and try to move it by hand. If it doesn't move smoothly then it could be seizing internally and needs to be repaired or replaced. 2) Disassemble the exhaust housing and check for any small items that may have snuck in past the lint filter somehow. If a small item made it's way past the filter it could jam itself in the blower assembly (which is most likely driven by the main motor) which would either cause the motor to fail or a belt to fail. Either way, **** out all the lint within the exhaust system while you have it open as it's good practice! :)
- Refering to the service wiring manual (which may be tucked away inside the control panel housing) is key. If the motor is not kicking on then you need it to trace its path for power and the signal to turn on. If it is turning on and moving, it's a matter of finding which physical piece is failing (which can be hard to do online).
- If the drum spins easily by hand then it's most likely in the hardware that transfers the energy from the motor to the drum. If it doesn't spin very easily, you may want take the drum out and check for any objects that may have wedged in between the drum and the housing. Also check the plastic shims and cloth gasket to make sure they have not worn excessively. Lastly, make sure the drum has not warped at all.
Dryers are fairly simple machines. Let me know how it turns out for you.
Oct 22, 2012 | Dryers
Kenmore dryer won't start
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Samsung DV218AEW Electric Dryer Logo
296 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
