Question about Maytag Dryers
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Amp draw
Sounds like it is working as designed. Igniters should last fro several years but can crack at any time.
Apr 18, 2014 | Magic Chef Ovens
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
I have a Maytag gas range model MGR 5729 ADW. My problem is this: 1. The igniter glows brightly 2. Burner will light with a strong woosh, but not until 2-3 minutes. 3. Burner goes out after about 30...
get in a gas fitter to properly diagnose the problem,
igniters in ovens normally click / flash as that ignites gas quicker than a hot wire so I suspect that is problem 1
problem 2 indicates that there is a gas flow problem, probably a faulty hose or regulator
what ever it is , gas is not in the domain of diy so an accredited professional gas fitter is required to do the fix
Apr 25, 2017 | Kitchen Ranges
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
Gas dryer ignites at start up then cycles off, won't re-ignite
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedures for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
The link below shows an image of the gas valve coils, which is the most common failure component in the system.
1. Gas Valve Coils:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG3000AWW-%3d%3di3479&PartID=3479
Below are some tips to follow if the coils are not faulty.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 28, 2009 | Maytag Dryers
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
133 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
