Question about GE Refrigerators
This one has been a problem for the last few weeks and I canâ??t seem to figure it out. I have a 3 year old GE profile Counter depth Stainless Steel Side by Side refrigerator. Itâ??s the nicest fridge Iâ??ve ever bought but the fridge section is too warm. It stays around 60 degree all the time. The freezer seems fine. Normally I would check the timer, and the thermostat, but the freezer is fine and nor frozen at all. This is a Dual Evaporator unit so the freezer is not connected to the fridge. I checked the small evaporator coils in the fridge section and they donâ??t seem very cold. The are kinda cool at best. What would cause them to be too warm? Arenâ??t they connected to the same compressor as the freezer? The evaporator fan is running to move the air. There is a good amount of condensation on the walls of the fridge. Also I just replaced the mother board and it made no difference. Model number: psc25mswa Can anyone help?
  • johnravelli Nov 11, 2010
    This one has been a problem for the last few weeks and I cant seem to figure it out. I have a 3 year old GE profile Counter depth Stainless Steel Side by Side refrigerator. Its the nicest fridge Ive ever bought but the fridge section is too warm. It stays around 60 degree all the time. The freezer seems fine. Normally I would check the timer, and the thermostat, but the freezer is fine and nor frozen at all. This is a Dual Evaporator unit so the freezer is not connected to the fridge. I checked the small evaporator coils in the fridge section and they dont seem very cold. The are kinda cool at best. What would cause them to be too warm? Arent they connected to the same compressor as the freezer? The evaporator fan is running to move the air. There is a good amount of condensation on the walls of the fridge. Also I just replaced the mother board and it made no difference. Model number: psc25mswa Can anyone help?
    Also its make a constant popping noise . its coming from the back of the freezer area about half up from the floor.
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
22yooper
  • 828 Answers
SOURCE: Kenmore side by side
Unplug the wires from the motor and check the voltage differential cross the two wires. If you have 120 Volts or in that area the motor should run. Try moving the fan shaft up and down. If you have any play in this the motor bearing are bad. Replace the motor.
Posted on Jun 20, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
  • 102 Answers
SOURCE: Sub Zero 642 side by side stainless steel leaks water from right
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Posted on Aug 05, 2009
Testimonial: "Problem solved, thank you!"
Loud noises in counter depth GE profile model pwe23kskess
refrigerators now a days have thinner cabinets & foam insulation, which resonates motor sounds . some high end refrigerators have added sound deadners which quiet the sounds somewhat.
Apr 27, 2018 | GE Refrigerators
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
How can i get the temperature to stay on it keeps shutting off it wont stay cold since it was left open 2 days ago
[PDF]General Electric Pfcs1nfzss Quick Specs - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../general-electric-pfcs1nfzss-q...
For answers to your Monogram,® GE Profile™ or. GE® appliance questions, visit our website at geappliances.com or call GE Answer Center® ... Counter-depth configuration - Counter-depth configuration makes it possible to have the look of ... Adjustable spillproof glass shelves - Raised edges keep small spills from ...
GE Refrigerator Not Running - Appliance Repair Guide
www.appliance-repair-it.com/GErefrigeratorrepair.html
In this GE refrigerator repair guide, I will walk you through the steps in ... They also added an electric damper that regulates the airflow between the fresh ... If you have aGE refrigerator that is not running the most common problem is ... Once the cover isoff, you should be able to see the main board. ... Temperature ControlMissing: pfcs1nfzss
GE Bottom Freezer Refridgerator fix. Evaporator Coil drain ...
? 2:25
https://www.youtube.com/watch?v=IiPRhr6nk54
Jan 01, 2016 | General Electric PFCS1NFZSS GE Profile...
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    I have a GE Profile side by side counter depth unit about 8 years old and the fan on the refrigerator side up top suddenly became noisy.Does this need to be fixed right away? Will it affect the cooling?
    Greetings,
    yes, sometimes these motors will make noise for years and other times, they go out pretty quick...so, to answer your question...it would be prudent to have it repaired.....Bruce Denton
    Dec 14, 2010 | GE Profile PSI23NCR Side by Side...
    I have a GE Profile side by side with water and ice in the freezer door, it is about 3 1/2 years old. The water was barely coming out of the dispenser, I changed the water filter and it is not any better -...
    We had this problem on our own fridge at home. it turned out the plastic lines which feed these appliances liable to fill up with lime and calcium which will restrict water flow. take a look at getting a new line.
    something else to look at. is the tube getting kinked when you push the fridge into postion?
    let me know if this helps. davcol47@hotmail.com
    May 08, 2010 | GE PSC23NSWSS Profile Counter-depth 23.2...
    Oven won't work
    Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
    Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Loud buzzing/rumble when running
    Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
    Jul 22, 2009 | GE Profile PFSF6PK Bottom Freezer French...
    GE profile counter depth side by side stopped
    Is the compressor coming on at all? If not a capacitor may be bad .
    Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
    Refrigerators Logo
    47 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
