Question about Philips DVP3020 DVD Player
What does "root" mean on
3 Suggested Answers
  • 476 Answers
SOURCE: Philips DVP3020 DVD Player - root?
ROOT is the startup menu, wher you select the various options on the DVD disc.
Posted on Feb 16, 2008
SOURCE: My dvd video player often
how do i find the lense ?
do i have to take the complete case apart ?
Help
I am neart boston
some of my previously recorded dvd's can not be read
i get empty dic : Message
am willing to pay reasonable fee for hands on solution
Posted on Oct 24, 2008
Dvd wont play disc root comes up?
When you load the DVD, instead of the content loading, the word "Root" comes up? This means the content is either corrupted, the disc is dirty, or damaged. In other words, the laser is not able to reach and pick up the magnetic information on the disc. Does this happen with another DVD player? Try doing that first. In the meantime, clean the disc. If the disc can't be read by another DVD player, then the disc is at fault. If another DVD player can load the disc with no problem, the original DVD player you used, may have a dirty lens (what the laser shoots out of), or the laser is not moving at all. If this is the case, the DVD player is broken.
Nov 25, 2014 | Office Equipment & Supplies
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Nov 21, 2011 | Cyberhome CH-DVD 300 DVD Player
What does root mean
root mean the basic contents in your disc
Jul 03, 2010 | KLH DVD8350 DVD Player
DVD PLAYER DISPLAYS THE WORD "ROOT"
no disc when there is a dvd inside. dvd works in another dvd player
Aug 18, 2009 | Memorex MVD2022 DVD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
My philips dvd player has stopped playing CD's and DVD's and on the display screen it shows "root". i have had this DVD player for 16months. Can you help me?? cheers
Usually "ROOT" is an indication that the player has read the DVD.
ROOT means that the DVD is in the main menu screen.
Sounds like the DVD player is ok, but you may have a loose connection somewhere.
Check all of your AV connections between the TV and DVD.
Also make sure that the TV is set to the same AV channel as the connection you are using.
E.G. if you have connected the DVD to the AV 1 socket of the TV, make sure that the TV is set to channel AV 1.
Apr 29, 2008 | Televison & Video
Root
"Root" means the player is reading the Root Menu of the Disc, which contains the title information, chapter information, etc - it is nothing to worry about.
Feb 21, 2008 | Philips HTS-6500/37 System
Feb 13, 2008 | Philips DVP3020 DVD Player
Philips DVP3020 DVD Player Logo
3,551 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
