Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-53WX53 5 flashing led code - Panasonic PT-47WX49 47" Rear Projection Television
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Five is short on one hundred forty volt line inside the set; Horizontal output transistor may be shorted or something near it.
Set detects the line is being held down because of a short and thus the five blink code.
Let me know if I can assist you.
SD TECH
Posted on Nov 10, 2010
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-53WX42F does not turn on, gives single flash code
my tv had the same problem and the B+140 was low. When I measured it, it was 89volts unfortunatly led me to the Flyback tra$former. after alot of troubleshooting work, I realized that the primary is short circuited. Also the horizontal output xsitor heats up alot on start up, thankfully it doesn't blow :)
I've had panasonic flybacks do this before to me. I havn't replaced my Flayback yet but when I pony up the $65.00 I expect (and pray) the TV to work fine. There is an off chance that something like the splitter or the foucus block caused this failure, but I doubt it.
Jul 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic rear projection 53" TV model PT-51hx43G. Just got this bad boy back from my ex wife and when i turn it on the power led flashes 3/5 times and goes dim. I have checked the power and...
count the led blink as thats an error code. If it blinks three times its indicating the convergence Circuit has failed. Let me know the actual blink number and I will assist you.
Jun 22, 2009 | Panasonic PT-51HX43 51" Rear Projection...
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
No power
can you tell me the number of flashes the LED indicator flashes as thats a error code.
Jun 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
