Question about Sport & Outdoor - Others
I have a Livestrong LS12.9T treadmill. It is time for me to lube the belt which I did and tried to reset the machine, it does clear the Lube for a few seconds and let me set it to walk but the belt does not move, the timer starts but nothing happens, then it goes back to lube the belt.? How can I get it to reset and run.
keepfituk
  • 11 Answers
SOURCE: The Walking Belt keeps staying close to the right side
speed the belt up to around 4mph while adjusting the belt. you will see it centre very quickly. once centered leave it to run for a couple of minutes to see if it stays central.
Posted on Jul 21, 2009
greenspan
  • 1734 Answers
SOURCE: i-run treadmill belt does not run
Maybe check the troubleshooting section of your manual. If you don t have one, check here.
Posted on Jul 23, 2009
SOURCE: Horizon CT-81 treadmill needs lube
100% Silicone Oil; 1000 weight viscosity :)
Posted on Jan 11, 2010
keepfituk
  • 11 Answers
SOURCE: where to tighten belt on reebok280 treadmill?
there should be 2 end roller caps, one on the left and one on the right. in these caps there will be an allen key bolt, turn each one a full turn to tighten the belt. continue to turn these bolts until you are happy with the belt tension.
Posted on Jan 24, 2010
  • 19 Answers
SOURCE: treadmill shuts off when I start walking/running.
Sounds to me like you have a bad Drive Motor. Doesn't hold a load and has to cool off before it restarts.
Posted on May 14, 2010
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
The stop button on my livestrong treadmill stopped working and now the lube belt message appeared but i can't reset the message because i can't hold the stop button. What can i do?
First you need to check your walking belt if is not creating to much friction, that's why you have the message, at soon you replace the belt the motor doesn't need to much power to push the belt and the message go away. You can buy the belt on HomeFitnessParts.com
Dec 21, 2013 | Exercise & Fitness
Getting a walking belt vibration and related noise when walking in the center of the track and close to the front roller. Vibration is not present when walking on the sides and at the rear. Machine is...
see the video attached and lube too the rollers bearing front+back very well.
test the drive belt motor, and the motor for to see if the motor is loose the bolts, or loose the belt or replace the belt if is damaged and tight a little with deflection 1/4" max.
I f the problem persist you have to replace the deck belt completely.
God bless you
Oct 10, 2013 | Livestrong Fitness LS10.0T-2 Treadmill
Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Nov 25, 2012 | Epic View 550 Treadmill
Error 32
LUBE OR wax you deck belt, this happen for autoprotection electronic system. To due a lack of LUBE maintenance schedule.Do it right now according with owner manual.
2)lube THE rollers bearings too use WD-40 for the bearings only
3) Test the drive belt motor, for cracking or worn belt, replace or adjust in according.
4) Test the motor voltage input, if there are the motor need repair, see my personal TIPS for troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 16, 2012 | Precor C966i Treadmill C 966i
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
Sport & Outdoor - Others Logo
225 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
