Question about Texas Instruments TI-84 Plus Calculator
My ti-84 is only graphing one linear equation in the y equal when i put two equations in it only show one
  • Texas Instru... Master
  • 8,080 Answers
The following should help you draw several graphs.
When you enter a function you should press [ENTER] to validate. At the same time, the cursor moves to the next line. Verify that the = sign on the equation already entered is still highlighted.
If for some reason the = sign of an equation is no longer highlighted, use arrow keys to move cursor on the = sign and press [ENTER].
If only one = sign remains highlighted and all others are not, then in all probability the application Transfrm has been executed before and is still lingering in RAM. When in RAM, it takes over the graphing capabilities of the native OS. This prevents you from drawing more than one graph.You must unload it from memory.
  1. Press the [APPS] key.
  2. Scroll down to the line that shows Transfrm.
  3. Highlight it and press [ENTER].
  4. In following screen you are invited to Uninstall or continue.
  5. Press the number to the left of Uninstall. Validate if need be.
  6. Return to the Y= editor to type in functions to graph.
Posted on Nov 11, 2010
How to use ti 84 plus calculator to graph linear equations
You have to use Y Editor to define functions on the both sides of the equation and then graph it. Finally option is F5: Intersection.
See captured images for equation 5x+10=-2x-7, y1=5x+10, y2=-2x-7 and x=-17/7
Feb 25, 2012 | Texas Instruments TI-89 Calculator
I am trying to graph a least-squares line on my TI-84 Plus. I have the numbers correctly plugged into my Stat Edit tables, and I am able to access my linear equation, and the first time I entered my graph...
After you enter the data draw the SCATTER plot first.
When you perform the (linear) regression analysis LineReg, save the regression equation to a function, for example Y1
The syntax is
LineReg L1, L2, Y1 ENTER
From the Stat>CALC menu press LineReg
The command echoes on command line
Press [2nd][1] to enter the L1 list on command line
Press [,] to separate
Press [2nd] [2] to enter L2 on the command line
Press [,] the comma again
Press [VARS][>][Y-Vars][1~Function][1:Y1] [ENTER]
Press [GRAPH] to have the regression line equation drawn
on the same screen as the Scatter Plot you drew before.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
I am entering information from a sample question for drawing a scatterplot and finding the linear regression equation. I have copied the example exactly and keep coming up with the same two problems. 1. I...
You might not see the scatter plot when you go to the graph because the boundaries are not set correctly. With the scatter plot turned on, go to "zoom" and then scroll down to "zoomStat" and hit enter. Try going to the graph again and see if the the scatter plot shows up. As for the the equation being slightly different than the examples, this is probably just the calculator rounding up the answers it gets. Good luck!
Jun 24, 2011 | Texas Instruments TI-84 Plus Silver...
When i did y= and put in -x+3 for Y1 and (x-1) divided by -3 and hit graph, it says ERR:SYNTAX please help. im trying to solve linear systems by graphing.
Try rewriting your equations in the equivalent forms that follow.
Y1=3-X
Y2=(1-X)/3
If you do not get a syntax error it means that you were not using the correct minus sign.
If the - is the first symbol after the equal sign you must use negation (-) or change sign key.
Similarly, after the division / key you must use the negation or change sign (-)
Oct 07, 2010 | Texas Instruments TI-84 Plus Silver...
My graph won't "reset" itself, after I went to the left of the origin and now I can't see any other solved linear equations
You can move the cursor back to the center of the graph.
You can also press [ZOOM][6:ZStandard] and the graph will be centered on (0,0).
Mar 03, 2010 | Texas Instruments TI-84 Plus Silver...
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
Nov 11, 2009 | Office Equipment & Supplies
How would you enter the following equation to graph on a TI-84 Plus Silver Edition calculator? 2 <= t <= 9
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
How to graph 2 lines at once
ok well go to the 'y=' button
type in the equation and make sure that the equals sign after y has like a black box around it, making the actual = white. so make sure both of those = signs of the 2 equations that you want to graph are like that, and thats about it.
Jun 19, 2009 | Texas Instruments TI-84 Plus Silver...
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
411 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
