Question about Dishwashers
Whirlpool ADP4502 - lights on but no water running - recurrent falshing red light indicating salt low but insoft water area so never used salt before
  • Anonymous Dec 26, 2008
    my whirlpool salt light is on and it seems the water is not running through the machine..just steams a little and a little water at bottom
5 Suggested Answers
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
SOURCE: Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Posted on Jan 09, 2008
SOURCE: l63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
Posted on Jul 06, 2008
  • 10865 Answers
SOURCE: dishwasher won't start
Hello there. There are three possibilities as to why your dishwasher is not starting up. Here they are:
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on May 20, 2009
  • 132 Answers
SOURCE: Salt level indicator not showing
of corse no:
there a sensor of salt independent of water hardness
so you can change the salt sensor if the problem persist
thank you
Posted on Jul 10, 2009
The low salt light is on and is not making chlorine. Salt level topped up yesterday as per pool shop sample. Chlorinator stopped sometime yesterday
the salt light indicates more than low salt level. now that you have eliminated that possibility, if the light is still on, there may be several possible causes. the cell may be dirty, or nearing its end of life, there might be restricted water flow or the water is too cold. these are all easy and inexpensive to check
Mar 06, 2016 | Pool & Spa
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
My generator first indicated low salt. I've added plenty of salt, and it still indicated low salt. I turned it off for 24 hours, and tried it again, now it has the service indicator light on,what next ?
We've found with our saltwater system (which doesn't have a service light, so not the same model as yours) that we have to add far more salt than we expect before the 'low salt' indicator goes off. It also seems to be very tempramental whenever it's been off for a while (such as over winter) & needs to run for very short bursts at first before working up to normal operating times.
Aug 02, 2013 | Intex Automatic Salt Water System for ...
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
To refill:
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Dishwashers Logo
112 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
