Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
I have no power to my zv 5000(hp). It has the power cord and everything. the charge light does not light up when it chgs... But when I first plug it in I get a 3 second spurt of blue light from the on signal....
  • 358 Answers
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Posted on Nov 12, 2010
Looking for a manual for an HP Pavilion zv 5000
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=385148
All the manuals should be found there.
May 08, 2011 | Computers & Internet
Dv6700 hp laptop wont power on
This is a dumb question i'm going to ask but is the power cord plugged in. Mine recently killed over. Come to find out it was the battery pack, which was fully charged, just didnt work anymore.
Aug 03, 2009 | HP ProCurve Switch 2650
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP ZV 5000 laptop AC adaptor switches to battery power randomly. The AC adaptor has only one year of usage on it and it works fine when the switch to battery power problem (luckily) doesn't occur. Also the...
We have two different HP Pavilion laptops, and they've both done this. For us it hs been the AC cord itself where it plugs in to the computer that has been the problem. Personally I think it is a scam with an imminent design failure built in. The cord bends right after the plug over an over again until the cables inside start to break and or short. At first you can get it to work by angling the cable just so until the charge indicator comes on, but after a while it just gets too far gone.
The scam part for ALL laptops that I have seen is that the cable is not replaceable. You have to replace the whole adapter. Of course the section of cable from the wall to the adapter is replaceable, but the cable from the adapter itself to the computer is hard wired, and that is the only part that breaks!
I have had minor success in repairing or replacing the ends, but the best fix is to get a new one. eBay has some for much cheaper than HP.
Apr 15, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
Battery connection
no... i have now the notebook on the technical service.
Oct 31, 2008 | Computers & Internet
Hp zv 5000 won't charge battery or turn on
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
Aug 07, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
No power
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Jun 28, 2008 | HP Pavilion dv1000 Notebook
Ive reboot my laptap hp pavillion zv 5000 but sound doent work
i agree with exon33 as long as you are useing realtec you can do that anything else and you better off using the disks that came with it
Apr 21, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
