Instrution manual for mig gas kende 150r - Computers & Internet
  • 4,737 Answers
There is no specific manual for Mig Welders but there's a common manual called Mig Handbook, you can download it here (Click Here). Open the link, it will open up in your browser, click "Download(524KB)" to download the Pdf file.
And here's all the tips and tutorials (video tutorials and flash tutorial included) [Click Here].
This is the Mig Training System-Online (Click Here)
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 11, 2010
What is the tip thread size of kende 150 mig welder . It's not standard euro torch
are you sure it's not a 1/4" 28 national fine? check the tip by threading it in a thread die
Apr 27, 2016 | Welding Tools
Cbr 150r fork oil
Fork oil spec and level/quantity: SOW 10 W - 206/131 cm3/mm
Here is a full service manual for the CBR-150R.
http://startright.co.uk/manuals/CBR150R.pdf
May 12, 2015 | Honda Motorcycles
I have a kende mig 105 gasless welder,but the wire isn't getting fed through on the feed wheel,tried different welding wire and also turned the wheel,tried tightening the wheel,slackening it as well,i
Here's a few things you can check:
When gun trigger is pulled, do the drive wheels turn? If they aren't, pull the trigger again; do you hear anything within the machine (contactors closing, gas solinouds opening, any clicking, etc.) that would indicate the trigger circuit is functional?
If the drive wheels are turning, but wire isn't being pushed thru the mig gun, check for proper drive roll vs. wire size. If that is correct, check gun liner for obstructions. Flux cored wire tends to stop up a wire liner fairly quickly.
Dec 21, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
Kende mig wel103 keeps breaking welding wire?
If it is breaking at the drive roller, chances are your spool of wire is too tight. It has to be able to spin freely as the drive roller pulls, but not too freely or you will end up with quite a mess inside there. Loosen the wingnut that holds the spool of wire and see if that remedies your problem.
If it is breaking somewhere else, let me know and I will try to help you.
Jan 06, 2011 | Welding Tools
Kende 150R gas/nogas mig welder
Hi I have the same welder with the same problem, I've striped it down and found that there are a few teeth missing on the gears that run the wire feed,
Had no luck finding any replacement parts though
Sep 05, 2010 | Troy MIG100 90-Amp. Wire Feed Welder
Honda CBR 150r 2010 owners manual (english)
look on e-bay for a full manual in english plenty of them about,
Apr 25, 2010 | Honda CBR 125 R Motorcycles
Computers & Internet Logo
636 people viewed this question
David Payne
David Payne
