Question about Tivoli Kloss Model One AM/FM Radio
I have a tivoli model 1. Over the time I have had (7 years), it has become more difficult to tune in to a station. Reception is fine when I do finally, after much fine tuning, get the desired station. In other words, as I am turning dial, there is extreme static, then the area wherein the station is seems to be miniscule, so I must go back and forth and hope to land on station... Hope this makes sense. My sense is that the tuning mechanism is dirty and must be cleaned, but I have no idea really. Ideas? Thank you, Erik Otsea
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Posted on Oct 18, 2009
AJIN G
  • 6694 Answers
SOURCE: I bought my Tivoli Model
hi,
There is a Gang capacitor behind the tunning knobe of your radio. If this gang capacitor is faulty it will make difficult to tune the station accuratly and also will make static when rotating the tuning knobe. You have to replace the Gang capacitor. To see the gang capacitor you have to oppen the radio. It will look like one the picture.
OK
Posted on Aug 26, 2011
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Variable condensator
My first solution was to clean the plates of the variable capacitors inside the radio, with isopropyl alcohol.
After that, for some time, let me listen and tune enough well.
But was an illusion: after some weeks the capacitor still add noise during the tuning. My disappoint about this radio is very high, as its price. The choice of this kind of variable capacitor is very big design mistake.
Nov 12, 2013 | Tivoli Kloss Model One AM/FM Radio
CANT GET AM ON MY RADIO. HELP!
AM reception depends on orientation of the radio. Take the radio from its handle (top side up) and rotate it until you find the best signal. If it has Automatic Tuning, take the radio outside, find the best direction and initiate the ATS. Once the stations are recorded in memory, tune to one radio and listen. If that reception is poor rotate the radio without changing the frequency on the dial.
Jul 06, 2012 | Radio Shack "Accurian" Tabletop HD Radio...
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
My three-year-old Model One has started making very loud popping/cracking noises intermittently on the FM band. It can work fine for several minutes, even half an hour or so, but invariably the noises...
I found in some cases that the tuning capacitor collects small particles of dust causing snaps, pops, and drop outs. One solution is get some electronic cleaning spray from radio shack or service shop. now open the back of the radio, look for square plastic box it is transparent and you will see metal plates with small screws. On the top you will see small round holes in the plastic, attach the supplied straw and spray inside two good blasts should do it. rotate the tuning several times back and forth this cleans the plates, until spray dries the station will be on wrong frequency until dries
Jan 07, 2011 | Tivoli Model One
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
I have hooked up all the wires in the appropriate color-coded order and my stereo has no reception. It has power but no reception. The antenna is hooked up also. It is a Kenwood KDC 119 and the vehicle...
Selecting the station. 1 Select tuner source Press the [SRC] button. Select the "TUnE" display. 2 Select the band Press the [FM] or [AM] button. Each time the [FM] button is pressed it switches between the FM1, FM2, and FM3 bands. 3 Tune up or down band Press the [4] or [¢] button. During reception of stereo stations the "ST" indicator is ON. 1 Select the band Press the [FM] or [AM] button. 2 Select the frequency to put in the memory Press the [4] or [¢] button. 3 Put the frequency in the memory Press the [#1] - [#6] button for at least 2 seconds. The preset number display blinks 1 time. On each band, 1 station can be put in the memory on each [#1] - [#6] button.
Nov 03, 2010 | Car Audio & Video
Oct 10, 2009 | Tivoli Kloss Model One AM/FM Radio
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
Tivoli Kloss Model One AM/FM Radio Logo
89 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
