Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2"
I have a Senco FinishPro 18 that hasn't had a lot of use, but quit working suddenly. The trigger doesn't feel like it's activating anything. I have good pressure, no leaks. I took the main chamber and piston assy. apart and everything is brand new looking. I still suspect something in the trigger mechanism, but can't see how to disassemble it. (there are rivets holding the trigger in place).
2 Suggested Answers
  • 65 Answers
SOURCE: my senco finishpro 18 won't shoot
the seal on the piston requires replacement all seals are o rings and can be supplied by your local bearing stockists also check that the blade is straight and has no burrs
Posted on Dec 03, 2008
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Looking for a diagram or schematic for a senco fp18
I have a SENCO FinishPro18 that I inherited from my son when he died a year ago. It has worked fine till now. It does not shoot a nail when depressed against a board and I pull the trigger. I don't hear air leaking, but it seems there is little pressure. Having taken apart the head, then the base, it all seems in good shape. I have not taken apart the trigger assembly, as the removal is a total commitment. Thoughts? I could use some help.
Oct 24, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Missing every second nail
2 possibilities
1 trigger valve needs replacement, piston not fully retracting every time
2 feeder spring needs replacement, less likely but possible
Sep 06, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart put it together. Shoots a couple of nails then stops. Press the nailer against the target pull the trigger and air comes out of the handle.
I just had the same problem with mine. Exact same symptoms. My guess is that your gun hasn't been used in a while.
I called Senco and they recommended removing the top cap, removing all o-rings (one at a time) gently stretch them, put a small amount of lithium grease in the o-ring track, and replace the o-rings. This fixed my problem and I hope it fixes yours!
Senco has awesome tech support for their tools. I will not buy another brand because of their support. 800-543-4506
May 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
I need a driver for a senco fineshpro 18
part number is EA0181 and I would go to Senco.com and under find a dealer type in your information to find a dealer close to you or they also have listed a toll free number for assistance. If I have helped you with your request would you please rate this response accordingly. Thank you.
Nov 12, 2009 | Senco Finishpro 25XP, 18 Gauge
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Once I connect the airhose to finishpro 25xp it leaks through the exhaust. what would cause this, and what repair parts would I need to fix it.
your air piston is seized,go to a parts store and get a bottle of "AIR-TOOL" Lube pour into air-line in the tool, put air in and excercise the trigger and make sure it works again,and also drain your air tanks too!!!
Oct 26, 2009 | Senco Finishpro 25XP, 18 Gauge
My Senco PC1010 Air Compressor just quit and won't power on, any idea what could be wrong?
on a compressor by the motor or on the pressure switch there will be a overload switch which may have tripped out push this back in and try it it is a black button pocking out the motor or switch buddy get back to me if this doesnt work budd
Sep 12, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
My senco finishpro 18 won't shoot
Nov 26, 2008 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" Logo
103 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
