Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Bottom of freezer has water dripping into it
My Maytage side by side has water dripping down in the freezer and it builts up with ice on the bottom. I took off the back panel inside the freezer and the drip pan under the coils was full of ice. I thawed it out but 4 days later water was coming out of it and forming ice on the bottom of the freezer again??
Ours too. Same deal. About every second day water coming puddling out of your freezer (wide-by-side model).
This fridge has been crap since we purchased it and this is just a new problem in a series of previous ones. Maytag WIDE by SIDE - water leaks into freezer and ends up frozen mess in bottom of freezer.  I took the back panel off but don't recognize any frozen drain hose.  More details please.  Thank You
  • 3 more comments
  • 0437 Jun 27, 2008
    water in bottom of freezer not sure where it is coming from. about 3 ins. of ice in bottom of freezer. Water is coming out under the frig.
  • Anonymous Jul 10, 2008
    I also have the same problem of water freezing up in the bottom of the freezer can anyone tell me where the drain is in this maytag side by side?
  • ysrun Jul 16, 2008
    Our Wide by Side is getting ice build up on the coils. We have to remove the back and thaw it out, talk about a giant pain! We purchased this 5 years ago and I am greatly disappointed to say the least!!!!!!!!! I am going to try the solution I found on line, allow for more venting, and hope that this solves our problem.
  • tschulz Sep 21, 2008
    I have the exact same problem. There is several inches of ice that forms at the bottom of my freezer and water pools on my floor. I have completely defrosted my freezer and it is still happening. What should I try?
  • Anonymous Mar 12, 2014
    drain pan is dry. how to access the drain as the back of fridge doesn't appear to be removable
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
    Scholar:
  • 68 Answers
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Posted on Jun 26, 2008
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Ice in bottom of frigidaire side by side freezer
clean out the drain hole with clorine bleach/blow out any gunk manually defrost unit.no hot water. no fault of siting.just a blocked vent...
Feb 08, 2010 | Frigidaire FRS26R4A Side by Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Mar 04, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
980 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
