Question about OKI B6200 Laser Printer
QUIERO SABER COMO RESETEAR EL CHIP DEL TONER LASER DE MI OKIDATA B6200 YA QUE NO ME RECONOCE EL TONER SIN EL CHIP Y NO LO TENGO
5 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: se puede resetear el contador de los tambores de
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Posted on Dec 01, 2010
puertobori
  • 7733 Answers
SOURCE: hola acabo de armar una
Apaguela.Desconectala de la toma de corriente y el USB..Apague su PC.Vuelva a conectar la impresora (USB y corriente).prenda su PC.
Posted on Dec 18, 2010
  • 30 Answers
SOURCE: tengo una impresora multifuncional hp
1) connect printer directly to wall
2) try different walloutlets
3) remove the ink cartridge and then clean it with a lint free cloth.. clean the printheads as well.
4) the unplug the power chord from the back of the printer and then press and hold the power button for 30 sec.. replug the power chord.
5) replace printheads as well as cartridges
6) service the product
Posted on Mar 27, 2011
SOURCE: Hola tengo una impresora B6200
hola como quito el error del panel de una oki b6200 me sale reemplaze fusor
Posted on Aug 31, 2012
Mi malibu maxx 2004 necesita un cambio de aceite cuando lo compre me dijeron qe el aceite que lleva es color azul pero me dicen que no existe ese color!
hola , tengo un carro malibu 2004 , y creo ke esta kemando aceite , hoy ke trate de prenderlo me encendio la luz del motor , le cheke el aceite y le asia falta , le puse , pero la luz no se le apaga y cuando le aselero tiembla cual podria ser el problema , me podrian guiar por favor
May 29, 2012 | 2004 Chevrolet Malibu Maxx
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Hola, necesito saber por que me pide un driver mi unidad de floppy iomega?, no lo encuentro y no puedo utilizar el dispositivo
tengo un laptop windows8 y cunado quiero instalar mi flopy drivers iomega no lo reconoce parece que es problema de compatibilidar que solucion seria el adecuado
Apr 26, 2011 | Iomega Floppy USB-Powered External Floppy...
Como desbloquear el maus de la computadora toshiba satellite a 135-s4527 lo tengo bloqueado por que antes usaba el maus de cable por el puerto usb y ahora quiero volver a usar su maus origil quiero saber...
Como desbloquear el maus de la computadora toshiba satellite a 135-s4527 lo tengo bloqueado por que antes usaba el maus de cable por el puerto usb y ahora quiero volver a usar su maus origil quiero saber como desbloquearlo
Apr 09, 2011 | Toshiba Satellite A135-S4527 Notebook
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Mar 14, 2011 | Logitech X-530 Computer Speakers
Mi pc PCChips Con la placa madre m955g v3.0 reconoce Enciende discoteca El duro y sí Apaga Que servicios PUEDE , Como lo soluciono , gracias
hola a todos tengo un problema con mi c.p.u.... ella tiene una tarjeta madre M955G V3.0 a Y es una pc chips,,, bueno la primera falla que presento fue que no ensendia.. le limpie la ram y nada hasta q le quite el junper de la bios para resetear.. y desde alli encendio la pc pero ahora no me reconoce el DISCO DURO NI LA UNIDAD DE DVD... SI ME AYUDAN SE LO AGRADESCO
Sep 17, 2010 | PC Chips M955G Motherboard
Poner a tiempo cadenas de distribucion ford motor 4.0 mod 2002
11marzo2010- Necesito que me Hagan favor de enviar el diagrama para poner un motor de un tiempo de 4,0 Ford Explorer
Sep 14, 2008 | 2006 Ford Explorer
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
OKI B6200 Laser Printer Logo
578 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
