Question about Solar 3 Almond Toggle Fingertip Touch Light Dimmer Switches
Installed simple switch with sliding dimmer and it works backwards. dimmer works properly but up is off and down is on. has only 2 black wires going to it. i reversed them with no change. has 2 gold terminals on one side, one on the other plus the ground terminal. why is it backwards? thanks
  • 3,287 Answers
Mike - you need only flip the switch in the box so that the brighten pad is on the top, and dim pad on the bottom. That should solve the reverse acting dimmer. Next, this switch is capable of working as a "single pole" (or S1) or 3 way (or S3) switch. This also tells me the the toggle doesn't have the words ON and OFF on it. I suspect that you want the switch to function as an S1 type - meaning that the toggle should be UP for ON.
That means that the wiring needs to be changed. Since the switch you're describing has terminals - and those I see on the internet have wires instead, you may not have the type of switch in heading you chose. No big deal, but I'm going through this blind. One of the terminals should be different from the others (not including the green one). This is called the shunt (or common) terminal for three way operation. For your S1 configuration, it will be the input or power in terminal. The other two gold terminals are the "switched" terminals. You need to remove the wire from the gold terminal it is on now - and put it under the OTHER gold terminal. Wires will be on the dark or odd colored shunt terminal and one of the gold terminals - a different gold terminal than the one we started on.
Once you've done this, the light will be ON with the toggle switch is UP and will brighten when the top pad is touched, and dimmed when the bottom pad s touched. I also saw a disclaimer warning about the use of metal plates. You must use a plastic or other non-metal plate for the switch to work properly.
This info should solve your problem - good luck!
Posted on Nov 10, 2010
    Novelist:
  • 107 Answers
I'm not 100% on this because you left out some information... but I have a pretty strong gut feeling on this.
First of all, can I assume this is a 3-way device being used in a single-pole application? You mentioned two gold terminals on one side, but another screw on the other side (ignroing the ground because that's irrelevent) - is that screw a different color? You need to figure out which one is the "common" terminal and which two are the "traveller" terminals (the travellers are usually the same color as one another, and the common is usually a completely different color/metal). I assume that for the time being, you have one wire attached to the common, and one wire attached to one of the travellers.
Assuming all the above is correct, the answer is simple. The product is installed upside down, and the wrong traveller is being used. If you flip the product around (down is up, up is down), that will put the dimmer in the correct orientation, but now your light switch will be backwards. THEN, take the wire that's attached to the one traveller wire, and attach it to the OTHER traveller wire. This will flip the orientation of the actual switch.
That should do it.
I have a dimmer switch with 2 red wires 1 black wire and 1 green wire
that is a 3 way switch. In order for that to work it has to be installed to a light with more than one switch. For example in a hall way and there is a switch at both ends of the hall then both switches need to be 3 way switches
Sep 11, 2014 | GE 18023 Dimmer Rocker OnOff with Slide...
Two wall sconces: pulled out old dimmer: 2 sets of romex and no ground. white wires wired together; two black wires, one hot. Installed new dimmer: on-off OK but only one light dims with buzzing. Dimmer is...
Okay. This is going to be easy.
You're in the middle of a circuit and that's why you have 2 Romex'.
The HOT black is the line side. It comes from the panel. The not-hot black is the load side. These 2 blacks go to the brass screws on the switch. The whites tie together and don't go to the switch, UNLESS there are 2 silver screws on it, then they go there. Watch the switch to see if it's clearly marked for LINE and LOAD. In that, the HOT black goes to LINE and it's white companion (from the same Romex) goes to the LINE silver screw. The 2 from the second Romex go to the screws marked LOAD.
In the sconces, you're going to find one that has 2 sets of wires and the other has one set. (I'm betting) The one that's working better, is the first one from the switch wiring.
Open the working one with the switch turned off, of course. Disconnect the wiring going to the second light. Make sure the first light works just like you want it to.
Now, take the 2nd sconce down and see if the wires are in the right places. White to white, black to black, grounds in place, protecting wires from the others. If all that looks fine, reconnect the wire running from the first light to the second. Even though these are still opened up. turn on the switch and see if the 2nd sconce works.
If it's still buzzing, try to determine exactly where the noise is coming from.
Some dimmers won't work with florescent bulbs, some don't like halogen bulbs. SOME don't like the energy-efficient curly bulbs!
The box/instructions for the new dimmer may point out what it's NOT compatible with.
If everything's connected correctly and there's still buzzing, I'm guessing that there's some mis-match between the new dimmer and the lights.
Feb 02, 2011 | Leviton Decora Light Dimmer Switch
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
I attempted to install a slide dimmer yesterday. when i pulled the existing switch off I had three black wires (two pushed in to the back of the switch and one wound around a screw) and one white wire...
The white and the black wires are both hot wires, and the green wire is for earth ground only. The green wire does not belong hooked up to the white wire.
The two black field wires should be attached to one side of the dimmer switch (one of the black wires from the dimmer switch)
The white field wire should be attached to the other side of the dimmer switch (the other black wire from the dimmer switch)
The green wire from the dimmer switch should be hooked up to earth ground only (any un-insulated copper wire that is inside the switch/outlet housing) and if you can not find it attach the green wire to the inside of the light switch outlet housing and be sure that it is attached to metal.
The other hall light switch that you are talking about must be connected inline with that light switch you trying to turn into a dimmer, and it should operate again nomally once you have connected that light switch properly, and if not check for any tripped circuit breakers.
May 17, 2010 | Leviton #L32-06631-WWP White Decora Slide...
Cooper S106P dimmer switch
Black hot wire connects to the black wire of the dimmer. the outgoing black wire will connect to the yellow wire located on the same side as the ground wire. the other yellow wire will cap off.
Apr 11, 2010 | Cooper Wiring Devices S106P-W-K 3WAY SLIDE...
The wall switch that I am replacing, with a 3-way dimmer switch, has 2 black wires, 2 red wires and a green wire. The new 3-way dimmer switch has 2 red wires, 1 black wire and 1 green wire. Question: How...
Ok the RED is Phase and the Black is Neutral... Green is Earth. you have an IN, Red wire, and an OUT Red wire, the rest just go color to color. So in the socket, one Red wire goes to one Red wire from the dimmer, the other Red wire in the socket, goes to the other Red from the dimmer, then Black to Black, and Green to Green. Be careful do NOT work on it live.
Feb 26, 2010 | Lutron DVW-600PH-IV Slide Dimmer with...
Problem w/new sliding dimmer
The problem is that the Cooper #9530DS-K-L is actually a 3-way switch and you need a single pole dimmer switch to replace your existing single pole toggle switch.
If you want to use the Cooper switch you have you can take one of the black wires and cap it with a wire nut and connect the other two wires, but frankly, you'd be paying about 2 times the price for a 3-way dimmer switch when you only need a single pole switch.
You should be able to return the switch and get the correct one.
You should only have (2) black wires on the proper replacement switch, plus a ground wire
Hope you found this very helpful and best regards!
Aug 07, 2009 | Electrical Supplies
Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
May 28, 2009 | Solar Levitron Decorator Style Slide...
Solar 3 Almond Toggle Fingertip Touch Light Dimmer Switches Logo
2,169 people viewed this question
Top Solar Electrical Supplies Experts
loft404
loft404
Level 1 Expert
obsteiner
T-Comtech Repairs
T-Comtech Repairs
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
