Question about Indesit W 123 Front Load Washer
Indesit washer dryer 1200 WIDL126. It trips the main fuse box when I close the door of the machine.
  • 1462 Answers
SOURCE: indesit WIDL126 washer/dryer
no magic to it. use a pair of pliers. you are unlikely to do any damage - just the thread stiff
Posted on Apr 28, 2007
jason0110
  • 66 Answers
SOURCE: indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Posted on Jun 15, 2008
  • 1075 Answers
SOURCE: Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Posted on Feb 27, 2009
  • 82 Answers
SOURCE: My Indesit Washer dryer WIDL126 will not work all
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
Posted on Jun 25, 2009
  • 92 Answers
SOURCE: Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Posted on Jul 07, 2009
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Indesit wd 125 had tripped a fuse switch
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Jul 27, 2009 | Indesit W 123 Front Load Washer
My Indesit Washer dryer WIDL126 will not work all the LED lights are flashing continually.I have tried turning off at the plug and then on again, but no good. Any answers please?
Hope this helps
jb
Jun 22, 2009 | Indesit W 123 Front Load Washer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
Indesit W 123 Front Load Washer Logo
62 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
