What is a fixed metering device - Heating & Cooling
    President:
  • 1,515 Answers
Hi, a metering device is a part of a air conditioner, freezer, and refrigerator that meters freon into the evaporator coil of the unit. A fixed device is a capillary tube on smaller units that is non adjustable. On units that are 5 tons and larger, the metering device is called a thermostatic expansion valve which can be either fixed at a factory setting, or can be adjusted to meter a certain amount of freon into the evaporator coil to flood it, or fill it with the correct amount of freon gas. They can sometimes get plugged up due to a dirty filter drier on the liquid line of a system, and will need to be changed. They are mounted right next to the evaporator coil and can be a job to change out. Cap tube types are brazed or silver soldered on, and some of the expansion valves can also be of the brazed type or have flare connections on them. They have a screen inside that can be cleaned, but its best when you tap into a system to change it out. I hope this has helped you out. Please don't forget to rate me on this as I no you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Nov 10, 2010
Water meter can not be fixed
Air Conditioners do not have water meters, only metering device,
Dec 07, 2013 | Heating & Cooling
I work for a schools district and a problem with our walk in. cooler is our condenser fan wasnt workin, dirty condenser coil. After I fixed those problems, my compressor is coming off on low pressure. It...
@50/300 I assume it's a med. temp R-22 pump down walk in. Head pressure sounds a little high, probably been overcharged to compensate for a restriction in the metering device (or malfunctioning TXV). Check the solenoid (if pump down), metering device, and filter driers first. If that fails, lineset restriction or non-condensables/water in the charge would be next on my list.
Sep 29, 2011 | Heating & Cooling
No output on either speakers or headphone, input meters are permanently lit up all the way to the red 0dB LEDs (i.e. overload). I have tried direct USB input and the USB LED on device lights up and...
Ive just fixed 5 of these :D (for a studio)
All had the problem with the signal clip being lit up as soon as you plug it in.
I found on every one, the component U9 had failed! (after 6 hours of probing)thought id post this up as i couldn't find a fix any other place!Checked the service manual, U9 is a:IC VOLTAGE INVERTER CHARGE PUMP UNREG TPS60403 SOT23-5
got mine from:http://int.rsdelivers.com/product/texas-instruments/tps60403dbvt/tps60403-60ma-250khz-inverter-sot23-5/5171208.aspx
soldered it in and jobs a good'n
Jul 17, 2011 | Alesis iO | 2 Sound Card
My Whirlpool LE5760XSWO dryer runs, but the heater doesn't work. Is there a fuse just for the heater which I need to check first?
yes there are limit devices located next to the heater assemble that you can test with a meter and should ohm out and if your meter beeps should beep at you and have contuinity...
if you do not have a meter you can by-pass thermostat with power off and made safe as a temporary only to test measure and see if unit will come on and heat then. they are just a switch but have a purpose so that unit does not over heat so DO NOT I REPEAT DO NOT leave it bypassed or there is a potential for fire solely to test out if you do not have a meter....also test your heater with a meter should be able to read through it with a meter and have contuinity from one end to the other......good luck to you hope you get it fixed.....
Jan 05, 2011 | Whirlpool WED9200SQ Electric Dryer
We just installed a new Goodman HVAC and the compressor lines freeze up. The technician that installed the unit cannot find the problem
Not to be critical, but not much of a technician if he cannot properly troubleshoot the issue.
Several issues can cause the freezing problems:
1. Refrigerant charge issue.
2. Improper equipment sizing.
3. Air flow issues.
4. Metering device issue.
First is under charge. But before making this determination several other things must be diagnosed and resolved.
Was the unit sized properly using a heat load calculation? You may not know what this means but a reputable, knowledgable contractor does. If the unit was oversized, it can cause the unit to freeze. If the indoor fan & motor were undersized. it may not be moving enough air across the coil and this will cause the coil & suction line to freeze.
Air flow issues, such as obstructions in your ducting or across your evaporator coil will cause the coil to freeze, thusly your suction line will freeze as well. Is the filter and evaporator coil clean? Are there any obstructions in the air passages (duct)? Is the duct work sized properly. Improper sizing of the duct work may choke down the required return air flow, and cause the coil to freeze.
The last issue could be a problem with the metering device. If it is an adjustable thermostatic metering device, was it setup to maintain a 12 degree suction superheat? If it is a fixed metering device, such as a cap tube device or bullet (orifice) device, it mat have a restriction (ususally a piece of solder or flakes from the soldering process clogging up the inlet screen). To easily check this, thaw the system out, start it back up when thawed and look for frosting or ice accumulation at the metering device outlet side. I fit does this rather quickly, then the system must have the refrigerant recovered (or pumped down into the condenser) and the blockage removed.
If it is air related, this must be fixed prior to properly trying to charge a system. Unless the proper airflow has been established, charging the system, or checking charge cannot be properly performed.
Sep 03, 2010 | Goodman Heating & Cooling
I put a new battery in 2 times and the battry is
Some feature on your opener must have a switch that is stick in the closed (on) position. Possibly, you put a near dead battery into the device? Please check with a volt meter.
You could check the device with a volt/ohm meter in the circuit ... put the meter between the + post of the battery and the + contact of the device. Put a wire on the - battery and the - device to complete the circuit ... if you are using power, there should be some amp reading on the meter.
May 31, 2010 | Lightwave Tech (200.0074)
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Whirlpool washer duet ghw9100lq1
Hi. this issue is being caused by a defective flow meter. this is part of the water valve assembly but, its not integrate and it can be replaced separately without replacing the entire water valve device.
Simply replacing the flow meter will fix this issue. I have posted a link below that will allow you to purchase this part online.
CLICK HERE FOR YOUR REPLACEMENT PART.
Please rate and god bless:)
Apr 21, 2009 | Whirlpool Washing Machines
I'm working on a Weatherking 10PJA with a 24AH. Is that a muffler or filter/dryer coming off of the compressor discharge line? What type of metering device is on the indoor coil? Thank you in advance for...
It is a filter, probably to collect either moisture or contaminents. This unit most likley has a fixed metering device oriface where the evaporator connects to the line set.
Aug 21, 2008 | Heating & Cooling
Garmin GPS 72 quits running
If you have the serial interface for your 72, go to the Garmin website and upgrade your Software. The latestes version 2.50 has a fix for that. You can find your version by going to the System Info menu.
May 14, 2008 | Garmin GPS 72 GPS Receiver
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
