Question about Maytag PYE2300AY Electric Dryer
Noisy and no heat - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Saturn 2002 heater fan is noisy How can I lube the heate rfan
it will be a case of stripping it down to access it
Mar 02, 2015 | Saturn Vue Cars & Trucks
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Laptop heats up and the fan is extremely noisy. its almost impossible to place it on my lap while working due to the heat.
This indicates that the fan is faulty and possibly the heat sink is clogged with dust.
A noisy fan could have a worn bearing, I suggest you replace the fan.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 16, 2011 | HP Pavilion dv4-1140go Laptop
Cozy heater HEDV25. It is noisy and doesn't heat the room!
you can have the gas company clock your gas meter to determine how many BYU;S of heat the unit is putting out, yes in shot burners are noisy.
Dec 01, 2010 | Cozy Enclosed Front Console Heater 20,000...
My nforce3 chipset is very noisy now. can I replace this?
i think your cpu is generating too much heat thats why cpu's fan tries to cool down the heat. i think you need to apply some thermal paste . if you don't know what i am saying then i think you better take it to a technician to do it because it is complicated work.
Jun 15, 2009 | Gigabyte GA-K8NSC-939 Motherboard
Noisy oven
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
Apr 25, 2009 | DeLonghi Ovens
The dryer machine when it is working its noisy and sometimes the heating elements trip off.
It is normal for the heating element to cycle off and on based on the dampness of the clothing in the drum. It may be noisy due to worn drum rollers, glides or others interior components.
Feb 26, 2009 | Miele Dryers
Vibration when heat only is on inside and out
Is it noisy always when running in heat or only for intermittant periods? Depending on where you live every 45-90 minutes of run time the heat pump goes into a cycle called defrost. The fan on the outdoor unit will shut off. the compressor will continue to run but in actually cool mode. this heats the outdoor coil and allows any frost or ice that is built up on the outdoor coil to melt. The compressor can get pretty loud in this mode and you may actually see steam coming off of the unit. This is normal. However if it is noisy all of time in heat check/clean your coils. If this doesn't remedy it have your refrigerant charge checked by a NATE certified Service Technician. Good luck.
Nov 22, 2008 | Goodman CLQ36AR49 Air Conditioner
Noisy during heating cycle
element is litlle bit bad.you need change element .
Nov 02, 2008 | Rancilio Silvia Espresso Machine
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
