Question about Kenmore Washing Machines
My washing machine will not spin or ajetate evrything else works?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This is the most likely (and easiest to check) solution.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Nov 10, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
Heavy loads like rugs do not spin and the machine jumps around and bangs into the wall. I have to turn it off and take my wash downtown to complete. The repairman says evrything looks fine. This is a GE...
Check for any movement from corner to corner (across corner to corner) if there is any AT ALL adjust legs to take up the movement / no movment is more inportant then being level a lot of techs miss this... anymore questions or problems just ask .....good luck
Feb 01, 2011 | General Electric WCVH6800J Front Load...
My oasis he is not a see through top but i keep getting the ul message and when it goes through the spin cycle it sounds like ajet engine. iS THERE A SENSOR THAT NEEDS REPLACED.Sears wants 129.00 to just...
UL is unbalance load. uL is displayed when the machine/motor control detects an
off-balance load, and is steady on while the washer runs a
mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the
load.If the mini-cycle is unsuccessful, uL will flash until the door
lid is opened, allowing the customer to view and
redistribute the load. Page 57 shows the suspension
rod removal to get the tub out. These rods (4) hold the tub in place. Sorry I do not have an oasis manual but this Bravos manual will give you an Idea. One of those rods could be worn to the point it is throwing the the whole tub off. If a rod is broken then the tub could be pressing against the base and binding the motor, causing that noise. You gonna have to check and see.
Nov 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washer is ajetating but will not fill with water
Fill level switch stuck or the tube from the tub to the level switch is obstructed probably where it attaches to the outer tub bellows.
Nov 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
MACHINE IS WORKING BUT SPIN FUNCTION MODE NOT WORKING
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 30, 2010 | LG WFT1071TP Top Load Washer
Kenmore22932 wont spin
Could be the lid switch or a coupling.
Read more
Mar 07, 2009 | Kenmore 22932 Top Load Washer
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
