Question about Garden
I need a diagrahm of a belt drive greenfield ride on mower
  • 718 Answers
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
I want to change the drive belt on my ride on mower the Brand is greenfield ride on mower
If you have not got a manual you can go to website to get a full blown spare parts manual with prices try that
Feb 03, 2018 | Garden
Greenfield Ride on Mower need to increase tension on drive belts
As a rule there is 2 ways.
1 is a spring loaded idler pulley and the other is to loosen the motor and pull it back.
Depends on the age.
May 14, 2017 | Garden
My Greenfield 12-30 mower constantly drops the Drive Belt. How do I correct this?
First make sure that you have the correct size belt.
Then make sure the belt you are using is not stretched or worn out. Check all pulleys and make sure they are not worn and that they are in alignment. Finally make sure that all the idler springs are in place. It is wither an alignment issue or a belt tension issue
Feb 02, 2015 | Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Garden Logo
2,808 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
