Question about Konica Minolta Magicolor 2530 DL Laser Printer
Konica Minolta 2530 DL First Page prints low, does not fully eject and printer jams with the second page stopping half way in. Removing the partly ejected page, pulling out the half way inserted page, then lifting and closing the lid and remaining pages in the buffer then come out fine.
  • lawcal658 Nov 11, 2010
    Thanks... and can you now tell me:
    Is the problem I described a "known problem" so that the solution you proposed is also a "known solution?" I hate to get into taking the printer apart (although I can do that) unless there is good reason to believe that cleaning the rollers will be a sure "FixYa."
  • lawcal658 Nov 12, 2010
    [The one suggestion I got which was to clean all the rollers was not based on the above being a known problem with the particular printer I have. I can't imagine it is a roller problem or other sheets of paper would also jam... which they do not. I am hoping I get a solution that relates to this being a known problem with a known fix]
    Guru:
  • 731 Answers
This should fix the problem.
  1. Open the printer up and removed the green drum, at the back in the middle are two small plastic flags that drop through holes where the paper runs.
  2. These flags can get pushed behind and so it reports a media jam, even without the paper.
  3. The top one is very high (easy to miss), but the lower one was my problem, with it sticking behind the hole.
  4. You can use a paper clip to pull out, but probably not a permanent solution.
  5. For permanent fix you have to remove the back of the printer, circuit board, to realign the flag in the middle of the hole, so as to stop it getting jammed.
Regards Riztech
Posted on Nov 20, 2010
  • 2,567 Answers
The printer needs to be disassembled & the rollers (especially the paper pick up roller) needs to be cleaned.
Posted on Nov 10, 2010
  • Mohamed Omran Nov 11, 2010
    Honestly, I did not troubleshoot this exact issue on Konica Minolta printers. But I had the very same issue with HP laser printers & the usual fix was to clean the rollers or replace them.
    I would suggest you get more advice from other FixYa expert(s) if you feel more comfortable doing so.
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Not printing full page
Verify the printer paper size settings and on PC the paper layout settings.
Dec 16, 2013 | Konica Minolta Magicolor 2530 DL Laser...
2530 DL problem printing, has a streak of white line all the way down the page. Has plenty of toner in it.
If all the toners are not empty, then you have toner or dust on the print head unit. Remove the drum cartridge and you will see beneath it a narrow glass, just be sure that glass is clean.
Jun 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
My magicolor 2530 dl printer keeps jamming
It is very difficult to remove the fusers. I did this once, and it was enough. Essentially, you must take the machine apart enough to release the metal sides enough to lift it out. Your best bet is a samll pair of medical hemostats and the green tabs up to release pressure. Dont use tweezers, because if you nick the red roller (it is soft) you will have blemishes from that fuser forevermore. I can mail you the manual if you wish to try. My mail is dhudson at Gmail, mprivate message me and I can send it as an attachment.
Apr 15, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta magicolor 5430 DL
pleas make color calibration from printer quality menu and try again
Apr 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
138 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
