Question about Xantrex Technology Heart Freedom 20 12 Inverter
My dad's Trace Engineering Legend Series 1 model L1512 inverter/charger overcharges the 4 coach 6 volt batteries when the coach is plugged into shore power. His coach is a 2000 model, and he has replaced batteries 4 times! He can't find his owners manual, and I couldn't find one online. Even with the batteries fully charged, I measured 14.6 volts being applied to them. I saw that later model inverters had a light that indicated whether the inverter/charger was in Bulk, Absorption, or Float mode, but I'm not sure if this model has that light indicator. The light is constantly glowing orange. Any ideas??
nitrospawn
  • 290 Answers
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Posted on Feb 26, 2010
nitrospawn
  • 290 Answers
SOURCE: HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Posted on Feb 27, 2010
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
Posted on May 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
  • 17 Answers
SOURCE: my freedom 20 charger/inverter does not seem to
The charger has four distinct charging stages - 1) Bulk, 2) Acceptance, 3) Float, and 4) Equalization. If your batteries are old and therefore won't reach full charge, the charger may not be able to get them up to the voltage where float charging kicks in. If you ever allowed the water in the batteries to get down to where the plates were exposed, one or more of your batteries may be contaminated with excessive sulfate buildup on the plates. The equalization process (Stage 4,which must be entered manually) will help to return any excessive sulfate builup back into solution, so you might try that and see if the performance improves.
Posted on Sep 27, 2010
I have a 2001 Trace legand series inverter modle L1512. Can i switch to Lifeline LL-GPL4CT 6 volt batteries with no changes to inverter?
If the inverter is intended for 6 volt batteries, and I doubt it, then yes. However, it is common to connect two six volt batteries in series to get 12V, which most RV inverters use. I have four 6 volt, series parallel connected batteries in my home providing 830 AH to run the house during the peak periods of the day. I have never had a problem with this set up.
Aug 08, 2017 | Inverter Electronics - Others
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
I need a Control Board for my TR2424.
why do you need control aboard where are you fitting it and to what i have one on my coach its wired straight from my batteries
Nov 18, 2014 | Xantrex Trace Series TR2424-120-60...
Trace, no power from line one from either gen set or shore power. Have rebooted, and when I invert the coach works normal. Charge system to house and coach batts perfec
If a normal install, the shore power and generator will go through a transfer switch then to the inverter. If when inverting 120 VAC circuits are OK, then the problem must be before the inverter. I would suspect that it is the transfer switch.
Disconnect shore power, make sure generator in NOT running then take a look at the transfer switch these are in a boat or RV but either can lead to vibration problems which can lead to loosening wire connections which can lead to heating and burning. It may be something as simple as a wire coming loose. (Which could be dangerous!)
Whether or not the contacts in the relays are OK, check and/or tighten all electrical connections. It's a good idea to check and tighten all electrical connections regularly.
Some transfer switches can be repaired by replacing just the relays. Other units (like mine this year!) will need to be replaced entirely.
Nov 11, 2013 | Xantrex Technology Trace Series Inverter /...
Inverting side working fine but charger is not
I had a similar problem at work yesterday.when your charger switches of it assumes that the battery is fully charged, while it is not.this is the solution , switch on you inverter machine and allow it to run, while it is running use a direct current "dc" multi meter a test the voltages of the batteries any one that drops like 3 volts below the normal voltage is bad. Change it and you will notice that the problem will stop. Note that when a battery is bad it takes little time to get it charged than when it is in a good condition .
May 26, 2010 | Xantrex Technology Xantrex Trace Series...
New batteries new cables still 99 volts output from trace inverter
What kind of inverter is it and what kind of meter are you using to check the voltage with? If the inverter puts out modified sine wave, you have to use a true rms volt meter to accurately check the voltage with. A non rms volt meter will show a low reading.
Sep 21, 2009 | Xantrex Technology Trace Series Inverter /...
My fredom 25 inverter is not running the refrigerator in my motor coach when I turn the generator off or unplug from shore power.
Is the inverter rated for more power than the refrigerator draws (watts). Does the coach 12 volt power drop (at the inverter) below 12 volts when the refrigerator comes on? If so, you may need to increase the wire size from the battery to the inverter. Make sure that the voltage doesn't drop at the battery. If so, it may need replacement or a larger capacity battery. When the battery is being charged, measure the voltage at the terminals (which are hopefully clean)--it should be 13.5 to 14.5 volts.
Sep 07, 2009 | Electronics - Others
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
I have a motor home with a Trace inverter/charger. When the unit is connected to shore power the system will recarge the battery pack fine. When they are charged the remote meter will switch from bulk...
More than likely you may a a relay that is stuck or not energizing which should switch the charging mode over automatically. Trace back from the generator to the charging circuit for the batteries. I'm not sure where the relay (or solinoid) would be located but you can be assured it is something in the charger sensing/switching circuit.
Good Luck! Gary
Mar 12, 2009 | Xantrex Technology Trace Series Inverter /...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
1,243 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
