Question about Homelite Garden
What fuel mix does a homelite xl-130 chainsaw require?
    Scholar:
  • 80 Answers
The homelite xl-130 gas/oil ratio is 32:1 meaning one quart of gas and one oz of 2 cycle engine oil or one gallon of gas and and one 4oz bottle of 2 cycle engine oil.
Best,Regards
obliqueridge
Posted on Nov 10, 2010
Correct fuel mixture for homelite xl cahinsaw UT10695b
50:1 unleaded fuel,1 gal gas to 2.6 ounces of 2 stroke oil mix
Jul 17, 2016 | Homelite Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
I have a Homelite XL Chainsaw, What is the recommended gas/oil mix, please? Clive
I have an older homelite that uses a 40 to 1 mix. It is about twenty years old but I think that is what homelite still uses.I hope this helps you. Thanks
Dec 27, 2010 | Garden
Oil to gasoline ratio for Homelite XL chainsaw?
50:1 using a modern synthetic saw oil and clean, fresh fuel to mix in it's own container (no more than a gallon at a time unless sawing is your business). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation in the engine. The engine should 4-stroke (at speed) unloaded, but immediately 2-stroke when cutting. Adjust the H jet needle slightly to achieve this operation. This provides the best power and coolest running. Hope this helps!
Nov 03, 2010 | Homelite Garden
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a 1979 Homelite XL Chainsaw model # UT 10045C Serial # 3E1930093. What is the fuel mix ratio for this saw?
32:1 according to this.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 14, 2010 | Homelite Garden
Have an older XL 16" Homelite chainsaw UT10695, Ser. No. HO0681042. Can't find manual for gas/oil mix ratio, thought it was 32:1??
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Homelite Garden
Garden Logo
366 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
