Question about Epson Stylus 1400 InkJet Photo Printer
I did the clogged nozzle check and it printed a very light line sequence. I tried head cleaning with same result. I changed all the cartridges. It doesn't even print at all.
  • cornwallinn Nov 12, 2010
    Am I to understand there is only 1 printer head?
    Is this somrthing that is complicated to replace?
  • Epson Master
  • 11,800 Answers
In this printer the cartridge is separated from the actual printing head. In your case the printing head is completely clogged and it must be replaced.
The printing head can only be obtained from Epson and it will cost you around $125 so you must decide if the printer is worth repairing or replacing.
Posted on Nov 10, 2010
  • Azrael SRL Nov 12, 2010
    The printing head is secured in the carriage with clamps. Releasing the clamps isn't very difficult,but it's a job that requires some experience - the small plastic clamps are easy to break and if this happens the printer is dead.
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Photos print with a faint 'pinstripe' effect
that could be head alignment (most noticible on low quality settings .. there is a procedure for aligning the heads ... or it could be clogged nozzles
to check these things start to print something
then select preferences .. then maintainence then
you have a choice .. nozzle check should be done first .. if all nozzles are working then go to "head alignment" and follow instructions there .. if some nozzles are not working then run the "cleaning" utility . sometimes it needs to do that several times .. if you cant get all nozzles working then you can try "deep cleaning" that uses lots of ink so you dont want to do that often ... if that doesnt work then you need new heads .. the heads in many pixma printers are easily replacable but costly ..
if all the nozzles are working and head alignment was done but you still have faint lines then try "high quality mode" .. in that mode you should not see any lines ..
Dec 23, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Poor colour
check out the cartridges it must be empty and needs replacement.
thanks.
Dec 28, 2008 | Canon BubbleJet i905d InkJet Printer
Vertical lines throughout photos
Solution: Clean The Print Head Nozzles (Windows) MP500 / MP800
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleanings or print head deep cleanings. nozzlecheckflow_en.jpg
Dec 19, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon BJC 3000
Printer attempts to print but no ink is on the paper Printer attempts to print but no ink is on the paper If the print quality is poor or no ink is appearing on the page, it may be because of the following problems:
  • The ink in the BJ tanks has run out.
  • The print head nozzles may be clogged.
  • The protective cap or tape may have been reattached to the BJ cartridge.
  • The BJ cartridge may need to be replaced.
  • You may be using the wrong side of the media.
To check the level of ink in the BJ tanks
Open the printer's front cover and visually check the level of the ink in all the BJ tanks. If a BJ tank is low or has run out of ink, replace it. Failure to do so may shorten the life of your BJ Cartridge
Check the status of the print heads by printing a Nozzle Check Pattern
The Nozzle Check Pattern confirms whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned.
  1. On your printer, press and hold the Resume button until the printer light flashes two times.
  2. When you release the button, the Nozzle Check Pattern will be printed.
    You can also print the Nozzle Check Pattern by clicking on the Test Print button in the Maintenance tab of the printer properties dialog box.
  3. After the Nozzle Check Pattern is printed, check the results.
  4. Look at the Nozzle Check Pattern for each BJ cartridge. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
  5. In the alignment head pattern, if the lines are not perfectly overlapped, align the print heads.
To perform the print head cleaning procedure
  1. On your printer, press and hold the Resume button until the printer light flashes one time.
  2. When you release the button, the print head will be cleaned.
    You can also clean the print head by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
  3. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
  4. Perform the Nozzle Check Pattern test again.
  5. If the results are satisfactory, resume normal printing.
  6. If the results are not satisfactory, you may need to execute a print head deep cleaning.
To execute a print head deep cleaning
  1. Make sure paper is loaded in the sheet feeder and the printer is turned on.
  2. Display the printer properties dialog box and click the Maintenance tab.
  3. Click the right Print Head Cleaning button.
  4. When the print head cleaning begins, the POWER light starts flashing. Wait for the light to stop flashing before you resume normal operation.
  5. Perform the Nozzle Check Pattern test again.
If the Nozzle Check Pattern is still unsatisfactory, you may need to execute a print head alignment.
To execute a print head alignment
  1. In Windows, display the Maintenance tab of the printer properties dialog box.
  2. Click the right Test Print button.
  3. Follow the instructions on the screens to perform an automatic print head alignment.
  4. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK.
  5. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
  6. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
  7. Perform the Nozzle Check Pattern test again.
If the Nozzle Check Pattern is still unsatisfactory, you may need to replace the BJ cartridge.
To replace a BJ Tank in a BJ Cartridge
Leave the BJ cartridge in the printer when replacing a BJ tank. Make sure the printer's power is on. Make sure you insert the BJ tank in the correct slot.
  1. Open the front cover.
  2. The power light blinks while the cartridge holder is positioned to the center of the printer.
  3. Remove the empty BJ tank by pressing in on the release tab and then lifting the BJ tank up and out of its slot.
  4. Dispose of the tank properly, taking care to avoid spilling ink on your hands, floor, furniture, or clothing.
  5. Remove the new BJ tank from its package and pull the orange tape up and against the perforations to open the package film.
  6. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
  7. Twist the orange protective cap to remove it.
  8. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
  9. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
  10. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
  11. Close the printer cover.
  12. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
  13. Perform another test print to make sure the new ink tanks are performing correctly.
To remove the protective cap and tape from the BJ cartridge
  1. Open the printer's front cover.
  2. Unlock the BJ cartridge by raising the cartridge lock lever. Make sure you raise it all the way up.
  3. Remove the BJ cartridge by holding it by the circles on the left and right sides.
  4. Make sure that the orange protective cap has been removed.
  5. Make sure that the protective tape has also been removed.
  6. Replace the BJ cartridge and move the blue cartridge lock lever until it locks in place.
To check the media:
  • Make sure that you are printing to the correct side of the media that you are using.
  • Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
Dec 17, 2007 | Canon BJC 3000 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
