Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2 gb usb pan drive
I have the same problem, a Write Protection error.
I have edited the registry, that didn't work...
I have booted from my windows CD to delete the partition, that didn't work either. (Just thought it might work that way)
I also tried to format it in My Computer, command prompt and in Disk Management, neither of that was a success. I also changed the the drive letter, you can guess by now what happened....... I can't do anything with my 2GB Kingston USB drive... Not even de-frag it, not to mention to copy my DATA to some place else... If any one has any suggestions, I surely will give it a try!! Because if have tried anything and everything that I could possibly think of !
You need to reformat using the Kingston web site go there, they have a utility for such, also it should have had a small cd enclosed to do a setup.
Posted on Jun 21, 2008
Can't remove write protection from my kingston datatraveler 4gb g2
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My USB DT200 128 GB Kingston has got a write protected problem even there is no write protection from my side please help me
also
- Click permissions
hope this helps
Mar 21, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cannot remove write protection from my Kingston Data traveller
also
- Click permissions
hope this helps don
Mar 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
also
- Click permissions
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 4gb kingston USB but it could not format. when i format it it show a massege " write protection error". please help me to format my USB. may u live long. Ch. Bashir Ahmad
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software from http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml and run it to execute a "low-level format" on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
If you do low level format, you may have to do a normal formatting after that. Just right click on the pen drive and select format. In the next screen accept the existing settings and click ok.
If these solutions doesn't work you have to edit registry settings. Find "StorageDevicePolicies" in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\. There may be a DWORD "Write Protect. Set the value to "0". This ahould work.
Nov 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove the write-protection in my FLASH DRIVE?
  1. Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "use device" or "driverdesc" to open usb mass storage device. right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
  2. Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
Jun 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Removing of write protected from kingston USB
is there a small switch on the side of the drive, which can be moved. its basically for write protection.
Otherwise its a problem with drive, and you need to format it. If that is not working then your drive has got corrupted and needs a replacement.
Jan 27, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
WRITE PROTECTION ERROR
when i pluged the usb it shows ,but the space on it is 0 bytes.
Sep 11, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protect Error
Hi ............
last month i purchased 4 GB pen drive. now it working in Write protected mode and accepting 1 GB data transfer. please suggest me solution for this problem to my mail ID
skumar529@gmail.com
Sep 04, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
62 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
