Question about American Standard 2002.800.021 Champion Right Height Elongated Toilet - Bon
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I have tried all adjustments I can think of and nothing works. I had an experienced installer and he is stumped. I had two others installed with no problem Do I have a defective toilet or is there a fix I'm missing?
  • 320 Answers
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Posted on Nov 10, 2010
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Nov 08, 2012 | American Standard Cadet 3 Right Height...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
Sometimes it takes several flushes to remove even a small amount of waste. Other times water spurts out of the toilet bowl when we flush. This is a brand new toilet and we are quite...
For now, just hold the handle down until everything goes down, common problem with low water use toilets, You may want to take this unit back and get another one.
Feb 13, 2011 | American Standard 2002.800.021 Champion...
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
Tank adds water approx once every Hr, how do I
Sounds like your flapper isn't sitting properly. Put food coloring in the tank and wait a bit - see if it goes into the bowl for a definite answer. A new flapper will cost about 6 bucks. Good luck.
Dec 28, 2009 | American Standard Cadet 3 Right Height...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American Standard 2002.800.021 Champion Right Height Elongated Toilet - Bon Logo
325 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
