Question about GPS
I need to change the time zone from pacific to mountain time on my Sharp atomic Clock model spc364. Also would download a manuel if it isn't too large.
I had the same problem. I got the answer (and it worked!) from http://wiki.answers.com/Q/How_do_you_change_Sharp_atomic_clock_to_Eastern_Standard_Time
Hope this helps. sundry99
Posted on Dec 27, 2010
  • sundry99 Feb 15, 2015
    Sundry99 update: The site listed above has been changed. Go to: http://home.comcast.net/~mark.flint/inst... for this info and other info about setting Sharp atomic clocks.
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do I change the time zone?
    Radio controlled atomic clock self sets, and self adjusts automatically. This clock is very easy to use!,Daylights Saving Time on/off option; 4 Time Zones - Pacific, Mountain, Central, or Eastern,Folds into smaller size for easy storage and travel; travel pouch included,Automatically sets day, date and time; 2 separate alarms - great for weekends,Sturdy, contemporary construction. Stand folds for easy storage. 2x AAA batteries included; as shipped to U.S. Government and institutions
    Oct 13, 2014 | Marathon Genuine Atomic Travel Alarm Clock...
    How to set timezone
    Hi Mary
    To set the timezone:
    • In the Normal Time Display, press the [MODE] button to enter the Alarm Time Mode.
    • Press the [SET] button to set the desired time zone. Refer to the Time Zone map on the display, P=Pacific, M=Mountain, C=Central and E=Eastern.
    • Press the [MODE] to return to the time mode position.
    Full instructions for all of the clock features can be found at the following link:
    Instructions Warranty for Atomic Clock Model SPC364
    Trust this helps
    Regards
    Alan
    Sep 27, 2014 | Home
    Need a user manual for skyscan model 31420e atom travel clock
    Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
    May 06, 2012 | Audio Players & Recorders
    Sentry self setting atomic clock lost the instructions
    Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
    The default time zone is Pacific zone.
    1. In the normal time mode, press the MODE key to enter the alarm time mode.
    2. Press the SET key to change the time zone.
    each press of the SET key will move the time zone back one hour
    P= Pacific M=Mountain C=Central E=Eastern
    3. Press MODE key when correct Time Zone is highlighted.
    I think the Instructions may tell you to use the ADJUST key instead of the SET key.
    ADJUST key does not work for TIME ZONE change, SET key works.
    This will set your clock to your chosen Time Zone for normal time.
    Instructions for the ATC20 are located at the following url
    http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
    Sep 28, 2010 | Office Equipment & Supplies
    Need instructions on 'programming' my Sharp SPC900 Atomic Clock. It has lost sync with the satellite and didn't automatically catch up with DST.
    I don't know about your atomic sync problem. But here is how you can set the time zone:
    Push the Time button once. This will change the Month/Day window to Alarm 1. Push the up button until the desired time zone is reached. Push the Time button twice more to return back to Month/Day display.
    Mar 15, 2010 | SkyScan 86709 Atomic Wall Clock
    Mt atomic clock is always 2 hours slow no matter
    How to Change the Time Zone
    Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
    Sep 26, 2009 | Acu-Rite Adagio Clock Radio
    I need to change time zone on atomic clock to EST
    I need help setting the time zone on the sharp atomic clock model #spc364.
    Apr 18, 2009 | Bose Wave Radio
    Sharp Atomic Clock spc 373 won't display correct time/zone
    To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
    Sep 23, 2008 | Zapf Chou Chou 716212
    GPS Logo
    359 people viewed this question
    Top GPS Experts
    Are you a GPS Expert? Answer questions, earn points and help others
