Question about Woods 3C 24 Hour Indoor Mechanical Timer (59366)
I just purchased a Woods tn300 and on the instructions it says to pull the pin out for on and in towards the center for off, the pins only go one direction and that is up. No pictures. Have you heard this and what do you think.
  • 8,197 Answers
Go to the link below to see some pictures on how the pins should be. About half way down.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Posted on Jan 23, 2011
How do I set the woods tn300 timer
just found this on the fixya site not sure if its what you are looking for.
Woods TN300 and Intermatic TN300 and Woods 59200 are same timer:
To confirm this is your timer, open link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
If this is not your timer, then add a comment for additional free service.
Instructions:
Rotate dial to set current time, when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour. Push segment down like piano key.
Segment pulled up = lights OFF
Segment down = lights ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Oct 22, 2017 | Woods Hardware & Accessories
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I lost instructions for Woods TN300. How do I set it?? THANKS and HAPPY NEW YEARS to all and BE SAFE!!!
Instructions:
Turn lamp ON
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone to help you solve problems
Jan 01, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I neeed the instructios for woods timer TN300 thanks
Intermatic TN300 timer is same as Woods 59200 timer
Timers are sold under different brands and numbers depending on who is packaging and marketing the product.
59300 manual:
http://waterheatertimer.org/pdf/Woods-59200.pdf
Turn lamp ON
If instructions above don't match your timer, see following page to identify timer:
Dec 13, 2010 | Woods 59200 Lamp and Appliance Timer with...
How do you pull the pins up to turn timer off?
You posted under Woods 59204, but Woods makes different timers with same number and others timers with multiple numbers
If this is not your timer, add a comment
http://waterheatertimer.org/pdf/Woods-59204.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59204
Manual for 59204 says segments are located around edge of dial.
Pull segments out with fingernail or small screwdriver to set on off times.
Here are some photos
There are two 2 basic types: Pins and segments
geno_3245_152.jpgTimer pins flip in and out using fingernail.
geno_3245_153.jpgTimer segments lift up using small tool or fingernail
geno_3245_154.jpgSometimes segments pull outward away from center
To check timer functions after setting pins or segments,
manually rotate dial to and watch lights turn on and off
Dec 08, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I can't find the pins that the instructions refer to.
Woods timers:
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Whwere are the pins to set the tomer on the 59204 model? Thanks
Woods 59204 is a plug-in timer rated for 1250Watts incandescent
The pins are 48 'segments' located around outer edge of dial;
Segments pushed toward center of dial = timer OFF for that 1/2 hour
Segments pushed out = timer ON for that 1/2 hour
Nov 18, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Woods 3C 24 Hour Indoor Mechanical Timer (59366) Logo
121 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
