Question about Hayward H-series Electronic Gas Pool Heater H400
My hayward h400 model h400ed2 will ignite and burn for about 1 min and then click off and about 1min later it will ignite again. It won't stay lit
mrgrzz
  • 88 Answers
SOURCE: MH 18 B wont stay lit
sounds like you have a limit safety issue, the unit is over heating and kicking out on high limit, or the limit is weak, either way you should look into replacing the limit, hope that helps
Posted on Jan 20, 2009
SOURCE: Hayward H400 heater problem
depending on your model- you may have to reset it after fixing it. I backwashed mine, had the same LO error code. I pushed "mode" through all the cycles (spa, pool, etc. then back to pool) and it started right up. (I hadn't noticed it but it told me to on the heater below where it told me the various error codes...referred to it as "lock out"). Saved a service call.
Posted on May 10, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
  • 990 Answers
SOURCE: Hayward H400 heater won't light and service light
This is a code for what is called a prover switch. What it is a circut for the air pressures. Depending on model you can have one or two of these. Their will always be one for the exaust perssure and this will often be the culpret. If the sensor is good a sooted exchanger, rat nests on the exchanger or in the exaust can cause this. If you have a second switch it will be for burner air pressure and you will look for the same problems only inside the burner cabnet. Good luck, I'm sorry I can't be more help. But at least you know to look to the vent system.
Posted on Dec 29, 2009
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
How can i to replace hayward thermistor for H400ED2?
pull off the side panel, the thermistor is located in the header and can be removed by backing out the nut, and then pulling the sensor straight out.
May 28, 2014 | Hayward H-series Electronic Gas Pool...
H400ed2 IF
(IF- Ignition Failure) It may be your flame sensor failing to recognize that the heater has fired. This will tell the gas valve to close if it does not detect a flame.
Dec 06, 2013 | Hayward H Series Pool & Spa Heater...
H400ed2 IF code
problem could me many things.....ensure proper gas pressure, proper voltage to spark igniter, all safeties are closed, etc
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H-series Electronic Gas Pool Heater H400 Logo
74 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
