Question about Cuisinart CBK-200 Bread Maker
My wife unscrewed and removed the lid of our Cuisinart CBK 200 C Convection Bread Maker in order to wash off bread that had baked onto the lid. In process the bracket to which the screws were attached fell inside the bread maker. How can I retrieve the bracket and put it in place so I can reattach the lid?
  • 1 more comment
  • Anonymous Mar 13, 2014
    need SPANISH recipe booklet for cuisinart convection bread maker CBK-200
  • Anonymous Mar 21, 2014
    Help~~My cuisinart CBK-200 bread maker cannot work, only the mix-up and start button on, not work for any other buttons...........try reset it but still not working (hold the stop botton for several seconds...)
  • jstantonm Jun 07, 2017
    The lid comes off the hinge if you open it to the right place and slide the hinge pin out through a slot in one end of the hinge. Re-installation will be easier if you don't have the whole lid attached to the hinge. Next remove the six Phillips head screws that attach the frame around the top of the oven opening and gently bend the frame back slightly. You will then be able to see the inside of the holes for the hinge screws. Shake the retainer out from wherever it is hiding and position it over the correct holes (there are two sets). You can then reinstall the hinge and screws, put the top frame back in place and screw it down, then reinstall the lid to the hinge the same way you removed it. No other disassembly is required.
  • 796 Answers
One is to try to turn it upside down or to dismantle the whole bread maker
Posted on Jun 17, 2008
  • isaac johny
    isaac johny Jun 17, 2008
    if it is on the base try to open from the bottom of the apparatus
How do I prevent crust from burning?
Hope this can help: http://www.overstock.com/Home-Garden/Cuisinart-CBK-200-2-pound-Automatic-Convection-Bread-Maker/5190276/product.html
Jul 13, 2015 | Cuisinart Cbk-200 2-pound Convection...
I cannot get the gluten free (9) MIX
Use reg bread setting with Bobs Red Mills G/F Bread mix. Works ok for
me.
Feb 18, 2013 | Cuisinart Cbk-200 2-pound Convection...
I can't figure out how to take the bread pan out. The instructions state to remove it and wash prior to use. There are no instructions on how to remove it.
Your pan is held in by two spring clips, one on each side of the pan. They are under tension in order to hold the pan steady while the mixing occurs. Lift the lid all they way open and grab the metal handle on the bread pan with both hands. "pop" the pan by lifting straight up with a little ****. That will cause the clips to lose their grip and your machine will kind of "pop" out. When you are ready to bake bread you may have to "pop" it back into place. Remember that.
In fact go ahead and practice popping your pan in and out so you get confident with how the little spring clips work.....so you will be ready next time you are ready to bake bread in it....Best wishes!
Jan 08, 2011 | Cuisinart CBK-200 Bread Maker
Cuisinart breadmaker displays E00 when i press the start/stop
That means that your ambient temperature is too cold to bake bread (page 17 of your manual). That means you may have been storing it in the garage and brought it inside. Recommend you put some hot tap water about half full and let close the lid and let is sit for for about 20 minutes. Then try pushing the start button and see if the warning is gone. If so pour out the water and bake your bread.
Please rate/vote for this answer or even better leave a testimonial ...thanks!
Nov 06, 2010 | Cuisinart CBK-200 Bread Maker
Pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
Dec 12, 2009 | Cuisinart CBK-200 Bread Maker
Were can I copy the Manual for the Cuisinart bread maker CBK-200
You can get it here.manual starts on page 94. The recipes are first.
http://www.cuisinart.com/share/man/483_man.pdf
Good Luck and Please Rate FixYa!
Jan 10, 2009 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
395 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
